Old 09-07-2007, 12:57 AM   #1 (permalink)
Default FM signal weak and distorted
Dear Sir or Madam,
Please advise what I should consider do to improve the (weak) quality of my FM receiver reception, and to connect with more (local) stations?
My media entertainment centre is located in my basement, some six feet below ground level.
  1. Static from my Samsung Digital Surround AV Receiver System Model HT-AS600 is a problem.
  2. There are several FM stations in our immediate band area. I am not able to connect into at least one. (98.5 FM)
FM Antenna Connection:
An FM antenna was supplied and connected to the FM 75 Ohm Coaxial terminal of my Samsung HD TV
AM Antenna Connection:
The AM loop antenna supplied is connected to the AM terminals.
I also have a CD player connected here.
Your advise will be appreciated.
Thank you in advance.
earleb
Ottawa, Ontario, Canada
earleb is offline
Old 09-07-2007, 08:06 AM   #2 (permalink)
Is actually a real word..
Default Re: FM signal weak and distorted
try googling, this site's pretty good as well http://www.rfzone.org/free-rf-ebooks/ have you tried to run a wire out the window and a little up the out side of the house. It's hard to say but definatly you want to get in outside and not 6' under behind concreate.
Oh by the way nice to see another Canadian on here, EH!
Liggy is offline
Old 18-07-2007, 07:26 AM   #3 (permalink)
Hi Liggy,
Thank you for your reply.
I've been out of town and just returned. Hope all is well with you, eh?
I haven't tried your suggestion but it sounds like a most reasonable solution to my problem.
I solved it by disconnecting my (short - three foot) antenna and replacing it with a speaker wire, extending it through a cable connector box and through it into my (unfinished) laundry room. I ran it to the highest point in the ceiling and voila, a perfect FM connection to my local station plus connections to many others.
How about that eh?
Where are you situated Liggy?
Have you ever passed through our heavenly (border) gates into our beloved Canada?
Hope we can share an e-mail or two...
Best regards and thanks again.
earleb
earleb is offline
distorted font, poorlyduck Tutorials 8 13-05-2007 12:26 PM
Any ways to boost weak mobile signal inside house? varun_ag Mobiles and Tablets 4 01-09-2006 03:52 PM
N\W SIGNAL NOKIA Vs SE ajith Mobiles and Tablets 8 30-03-2006 11:53 AM
Re: Cable Signal Booster harmads QnA (read only) 2 15-09-2004 11:20 AM
- by Krow
