07-07-2007, 05:48 PM
D i s t i n c t l y Ahead
how to protect my eyes ?
eyes r precious . HOW can i protect them from the adverse affect of
monitor radiation ?
HOW can i adjust my monitor settings ,windows xp settings ,etc ?
i m having 17 inch samsung monitor . i wear spects
plz dont advice to buy flat moniter i cant afford it right now
07-07-2007, 07:00 PM
What?
Re: how to protect my eyes ?
Yeah go ahead protect ur eyes . I wish i wud have cared 4 them too.Now my power is 3 D(myopic) so better care 4 them
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
07-07-2007, 07:13 PM
monitor radiation ?
The best choice an LCD monitor is ruled out. *sigh*
07-07-2007, 10:03 PM
ॐ
Anti glare screen is the best option.......
also u put pop up program in windows which gives u notice every half an hour "Cool Your Eyes with Cool Water"
**#(o)#**
07-07-2007, 10:16 PM
1->Rest for some 10-15 min after every half an hour.
2->Eat lots of fruits rich in vitamin A.
3->Drink lots of water when working on pc.(I am not sure about whether this helps,just heard it from a computer software engineer.)
4->Set the monitor Brightness & Contrast to 40.(I have set this value on my samsung 17 inch monitor & now my eyes feel less stressed.)
5->Also set refresh rate as high as possible for smoother display.
07-07-2007, 10:25 PM
Don't look continuously at the monitor. Every 15 mins. look some green plant (grandfather says). Keep long distance between the monitor and ur eyes.
KDE on ArchLinux
07-07-2007, 11:41 PM
You gave been GXified
Stop working on computers for timepass & things which are not required.
Start using it like a tool or consumer device.
Remember, real life is better, so get out, do things....& decrease the time u spend on computers
about.me/gxsaurav
07-07-2007, 11:50 PM
thanks all for Ur precious suggestions
@gx_saurav :thanks buddy U r right i will decrease my sittings
08-07-2007, 03:12 AM
Still Shining!
Reduce the screen brightness and contrast as Cool G5 said. I too have done that. After every 15 minutes look at darker things or close your eyes for 5-10 seconds to give some relief.
Girls?
Nokia N86 8MP
08-07-2007, 08:45 AM
UbuntuUser
Use the eyedrops: Cineraria Maritima Schawabe  . It is expensive; 135 for a small "shishi". But after using it for good 15-20 days (once a day while going to bed) you will definately feel the difference.
PS: It hurts like hell when you use the drops, your eyes will painfully pain. But a little pain can be bourne if you have to get your "jyoti" back
09-07-2007, 12:59 AM
******IMPORTANT POINT WHILE CALIBERATING CRT/LCD MONITER******
always reduce brightness to minimun like 20-30value and increase contrast...
most people increase brightness to remove darkness but contrast should be increased keeping brightness 20-30
use antiglare screen it looks bad hanging on moniter but it is better as compared to the +4 power spects hanging on your nose....
agreed or not??
also wet your eyes and don't soak up the water on your face with towel or anything.... just let it evaporate by itself .. this makes sure it uses up the heat generated in your eye area....try this and you will REALLY feel better....
everything starts with a zero and ends in one.
14-07-2007, 01:38 PM
well as suggested by u all i m planning to buy
anti-glare and anti-radiation monitor filter for my 17inc samsung moni.
can some one tell me is there any specific brand i should go for ?
nd what to look before buying ?abt how much will it cost ?
15-07-2007, 01:37 AM
have'nt seen any strong brand yet just check for the uniform blackness of the screen.... besides it would be good if you get the sticky pins to put on the moniter....they make the screen fit in a straight fashion and comfortably
branded ones are always preferred...
15-07-2007, 09:56 AM
Still Shining!
There is a Anti glare screen available from Frontech, and it is pretty decent
Nokia N86 8MP
Search this Thread |
