Hi guys...
I just purchased a sony DRU830 DVD Writer. But when i opened the box there was no warranty card in it.. anyone who has purchased this product did they recieve a warranty card. Now i am not sure if this is a genuine piece or not.
Is it an OEM product? You should always check the Warranty applicable to the product when buying and if it is not mentioned anywhere ask the seller and also insist that he puts it in the bill, rather than trying to break your head later.
U dont need any gurantee card........just the bill and serial number written on the DVD writer.
When you will go to any service center ..they will check ur warrenty by the serial number.
It does mention on the bill a S/N. But the dealor had given me 2 prices one was box packed which was expensive to a open one which was a little cheaper. Now i am confused if he has given me the open one. How can i tell the difference between the two.??
