28-02-2005, 03:45 PM
Cool as a CUCUMBAR ! ! !
svchost.exe
many times i get the message of error 4 svchost.exe & low memory ...
after that cant watch movies or listen 2 songs ...
have 2 re-start again ...
is there any other shortcut solution 2 start or get rid of this error ???
coz i also use w2k ...
its painful 2 re-start again ...
01-03-2005, 11:32 AM
no shutdown error ...
just ... error log created ... & i get a prompt of svchost.exe has created error, press ok.
After i press ok, many of my application do not work.
If i click on media player it says low memory & even my norton couldn`t get updated & even cannot dissconnet my modem, bt have to shut it manually or re-start it .
whot is the prob & any faster way 2 re-start or boot 4 w2k ???
... W H O T ...
01-03-2005, 01:28 PM
it's mostly a virus, download this removal tool and run it....
http://securityresponse1.symantec.co...oval.tool.html
and do a Virus scan in ur PC....
http://housecall.trendmicro.com/
also, post the HijackThis log file content here.....
u can increase Virtual Memory by doing this:-
1]Click Start>Settings, click Control Panel, and then double-click System.2]Click the Advanced tab, click Performance Options, click Change, reset the "Initial Size" and the "Maximum Size" values to some larger values.
http://swatrant.blogspot.com/
01-03-2005, 02:37 PM
SymbianGeek
Best solution would be to install win2k sp4 if u can get it from somewhere.
Bye.
--eminemence.
01-03-2005, 08:50 PM
 i was having the same problem,nd the only solution that came for rescue was SP2 for XP,will be SP4 for 2k....i had tried fixes,tools nd what not,but it always reappeared.....after SP2,everything is fine nd smooth!!!!
01-03-2005, 09:10 PM
in my processes there are five instances of it
does it mean i have a virus?
how many instances are there in your computers
01-03-2005, 09:17 PM
no, svchost.exe is a legit windows service  . So dont worry.
01-03-2005, 10:30 PM
why need title?
svchost.exe is the name for Microsoft Service Host Process, a critical system process that should not terminated at any cost. It handles processes executed from DLL files and is very important for running your OS in a stable and secure fashion
get the stinger tool from Here run it from a secure place..
03-03-2005, 04:04 PM
Svchost asks for permission to access internet ?
should i allow it??
You and Me forever be ...
PSpwned
03-03-2005, 04:08 PM
SymbianGeek
No don't allow it.
Bye.
--eminemence.
03-03-2005, 05:02 PM
why need title?
@chacko.. never allow that.. run stinger tool from the above given link n try it.. it should help u fix your probs..
04-03-2005, 02:01 PM
according to Zone Alarm it says its okay to allow cuz loads of p2p softwares need it....
PSpwned
04-03-2005, 02:02 PM
The Stinger tool did not dettect anything///
PSpwned
04-03-2005, 02:16 PM
why need title?
hmm download hijack this and paste log..
do u have latest version of HijackThis, that is 1.99?
if u have this, then when u open HijackThis, it will give u an options screen, here there will be many buttons like "Scan computer and Save log file", "Scan computer only" etc..
Here u click, "Scan Computer and Save Log File", after this it scans ur comp and opens a Dialog box for saving te Log file, it automatically gives it a name as hijackthis.log, u click OK.
then open this "hijackthis.log" file in NotePAd and copy the entire content and post it here.....it will be approximately 1 page...
http://www.spychecker.com/program/hijackthis.html
Search this Thread |
