05-07-2007, 11:16 PM
The Thunderer
My Ram Problem
I have a Intex Computer, with Processor of 3.06 GHz, P4, Intel Inside, with Windows XP SP2, and I have two SD RAM each of 256 MB which in together should be 512 MB but I get only 409 MB Ram when I check my properties. Why is that? How can I utilized all the 100% of my RAM?
05-07-2007, 11:18 PM
Still Shining!
Re: My Ram Problem
Rest memory is used by your graphics adapter.
You can't utilize to full, though.
But you can reduce the amount allocated to graphics from the BIOS.
Nokia N86 8MP
05-07-2007, 11:21 PM
The Thunderer
Re: My Ram Problem
By the way, I am new to this world of Computer so, what is Graphics Adapter or people says it graphics card. Where can I find it in my system?
05-07-2007, 11:24 PM
I Sell Brains,Any Buyers?
Re: My Ram Problem
From your details there above, i think you have to be using Intel Original Motherboards and not other chipsets. Just press F2 or del on your keyboard and go into your setup. Then go to the advanced tab and go to the video adapter option and reduce the memory used to a lower one like 4MBs rather than 32MBs. CAUTION: THIS WILL AFFECT YOUR PC'S PERFORMANCE IN GAMING. YET IT WILL IMPROVE THE NORMAL EFFICIENCY OF YOUR COMPUTER
Regards,
Pranav
-- I InventeD Microsoft, Gates Made it Famous --
Intel 975 XBX2
Intel Core2Duo 6600 @ 2.40 GHz
2 GB Transcend DDR2 667 MHz RAM
250 GB Western Digital SATA-II
Nvidia 7300LE 256 MB Graphics Card
05-07-2007, 11:28 PM
The Thunderer
Re: My Ram Problem
If it effect the performance of my gaming then I better be happy with what I have right now. I don't wanna get bored. Thanks anyways.
05-07-2007, 11:29 PM
Still Shining!
Re: My Ram Problem
Whatever you see on the screen is processed by the video card. You might be having an intel 865/915/965 adapter or others like ATI radeon, Nvidia etc onboard.
Those onboard ones use the system memory to process. This is allocated by the system.
In your case, some 100 MB is allocated. You can make it 64 Mb if you like, but at the cost of display perfomance.
The more the graphics memory, the better your games will be.
Nokia N86 8MP
Reason: Automerged Doublepost
05-07-2007, 11:32 PM
The Thunderer
Re: My Ram Problem
Uhmm...Thanks and keep me teaching more which you think I should know ya....I will be happy to know more about Computer....
05-07-2007, 11:47 PM
Still Shining!
Re: My Ram Problem
Nokia N86 8MP
06-07-2007, 01:03 AM
NP : Crysis
Re: My Ram Problem
i have 1 gb ram and an ati radeon X1600 pro 256 mb gfx card yet my sys only shows 960mb ram. why? i'm not sharing any ram with my gfx card
06-07-2007, 02:22 AM
TechTin.com
Re: My Ram Problem
I have one ponit.
RAM manufactures consider 1000KB=1MB
But XP calculate 1024=1MB
So,system property shows less RAM than inatalled RAM.
06-07-2007, 06:49 PM
Is actually a real word..
Re: My Ram Problem
do you have a sound card? you maybe sharing RAM for the integrated sound, if not the case, yeah what ravi_9793 said.
Search this Thread |
