Old 28-02-2005, 11:45 AM   #1 (permalink)
Maverick340's Avatar
Default Spyware Creeps!
I dunno but frm somewhere Loads of spywhere and Search bars have insatlled on my PC ...I ran Spybot and Ad-aware but they cudnt erase those specific ones...What do i do?
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 28-02-2005, 11:55 AM   #2 (permalink)
Ethan_Hunt's Avatar
here's Batty's sticky thread on guiding for the Spyware removals which was just above ur head http://www.thinkdigit.com/forum/view...=11368....ohhh i mean on top of this section....removing specific ones are very tough as depends a lot on the infection and the damage that they have caused to ur system....plus Adware tends to find out most of em....but if some are left then i guess A clean format would be a good option...
Good luck
V for Vendetta
Ethan_Hunt is offline
Old 28-02-2005, 04:06 PM   #3 (permalink)
swatkat's Avatar
uninstall all the toolbars if u find them in Add/Remove programs, and post the content of HijackThis log file here......
http://www.spychecker.com/program/hijackthis.html
http://swatrant.blogspot.com/
swatkat is offline
Old 28-02-2005, 06:11 PM   #4 (permalink)
hi bro:
My server was infected with spyware.The net connection was denied by the spyware.Sometime the keygboard couldnot function & stm mouse.The yahoo anti spy that I had installed was gone without my knowledge.Finally,I formatted my drive & reinstall every software.Now its working ok.
So, I guess formatting is the right answer according to my experience.
If u find any better, plz share
Roxin,the net guy
roxin is offline
Old 28-02-2005, 09:59 PM   #5 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Formatting should always be the last-ditch effort on getting rid on any infection.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 03-03-2005, 01:56 AM   #6 (permalink)
DONT U USE A PROPER FIREWALL.
IF NO YHEN I AM TELLING U THAT U R LUCKY TO SEE UR PC STILL FUCTIONING. TRY TO USE 'ZONEALARM'.
ITS LATEST VERSION SHOULD BE USED.
TRY THIS LINK
www.trjoanfinder.com
suj_engico is offline
Old 03-03-2005, 02:03 AM   #7 (permalink)
i feel that spybot is not a very effective antispyware.
this is because peple using it have found many flaws in them. i am an addition to that.
some say that some unreliable antispywares infact act as spywares themselves.
so be carefull in selecting them.
- by Krow
