Old 05-07-2007, 12:51 PM   #1 (permalink)
NP : Crysis
xbonez's Avatar
Default seeding in torrents
hi,
i use bitlord torrent cient. when i finish downloading a file, it starts seeding automatically. this affects the upload speed of the next file i start downloading which in turn affects its download speed. how am i supposed to seed in this case?
xbonez is offline
Old 05-07-2007, 04:56 PM   #2 (permalink)
drsethi's Avatar
Default Re: seeding in torrents
It is a good manner to seed after getting the file. If number of seeders is great your upload rate wil not be affected much. However if you like you can remove the torrent any time after downloading it.
drsethi is offline
Old 05-07-2007, 05:09 PM   #3 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
On which connection are u?
I am on BSNL 900UL plan. u/l speed never affested my d/l speed.
But as drsethi said, u can anytime remove the file from seeding list. Just highlight it and press delete from keyboard. (This methos is for utorrent but I think it will work for bitlord too.)
Quiz_Master is offline
Old 05-07-2007, 08:14 PM   #4 (permalink)
napster007's Avatar
your internet connection must s**k. or u must be downloading at night. i get speeds upto 4mBps!!
napster007 is offline
Old 05-07-2007, 11:32 PM   #5 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^4MBps ???????????? which connection u have ????
n00b forever...
~Phenom~ is offline
Old 05-07-2007, 11:54 PM   #6 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Follow the tut in Below link
Torrenting For Dummies
rakeshishere is offline
Old 06-07-2007, 01:15 AM   #7 (permalink)
NP : Crysis
xbonez's Avatar
^^no, no the prob is not that i can't remove completed torrents. i can do that but i feel very guilty if i don't seed it. the prob is if i seed it, the upload rate of other downloads is affected (since i have a limited upload rate of 256kBps on a 256 kbps line). torrent clients give download rates proportional to upload speeds so my dl speeds drop. how do i seed then?
xbonez is offline
Old 06-07-2007, 10:12 AM   #8 (permalink)
UbuntuUser
cynosure's Avatar
1) Check the maximum ul and dl speed of your net connection, using any site dedicated to do the same.
2) Cap your ul speed to around 70-80% of the maximum ul speed.
3) Your download speed should be set to unlimited
4) Enjoy downloading.
This way, you can upload whatever you can and download at full speed too.
If your ul speed is too much, then it can decrease your dl speed.
cynosure is offline
Old 06-07-2007, 10:40 AM   #9 (permalink)
Thor's Avatar
Your client must have an option to limit the upload speed. Restrict it to some value ....you find optimum. Generally 80% of total upload bandwidth sholud be allocated at max for upload. SO choose a value between that.
Not always true. Theoritically that should be the case, but it isn't.
Try it out.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 06-07-2007, 02:00 PM   #10 (permalink)
drsethi's Avatar
In windows bittorrent gives very good ratio of upload and d/load about 1:5, try it. In happy hours 2am to 8am I can d/load more than 3GB
drsethi is offline
Old 07-07-2007, 11:10 AM   #11 (permalink)
HELP AND SUPPORT
@xbonez
See the Link I provided..It solves all ur queries
Old 07-07-2007, 05:07 PM   #12 (permalink)
morpheusv6's Avatar
4 Mbps???:co nfused:
Deven
morpheusv6 is offline
Old 08-07-2007, 11:23 AM   #13 (permalink)
NP : Crysis
xbonez's Avatar
don't listen to him. he's neck deep in bliss on seventh heaven. he has an ordinary MTNL 256kbps unlimited connection but for some reason he's getting high speeds. i tell him everyday that its jut a matter of time before he comes crashing down to mother earth, but hes making sure to enjoy it while it lasts
xbonez is offline
Old 09-07-2007, 01:13 PM   #14 (permalink)
napster007's Avatar
ya thanks for ur reply xbonez or should i say (mappy) ha ha ha
Torrents... GeekyBoy QnA (read only) 6 27-04-2007 08:41 AM
What is Torrents? Gigacore QnA (read only) 7 18-04-2007 10:33 PM
Torrents ovr lan?? lionelxp Software Q&A 1 15-04-2007 03:35 AM
TORRENTS??????????? SHell QnA (read only) 3 16-11-2004 06:40 PM
- by Krow
