Old 05-07-2007, 07:23 AM   #1 (permalink)
free as a bird
Default dvd not loading
hi guys my dvd rom drive is not loading digit dvd by itself i have to open the dvd and the double click the digit file to load it , my dvd burner is loading it properly and i have autoplay enabled and as well as i have check the registry it does have autoplay enabled, but still dvds are not loading by default.
plz help .
vicky_l7 is offline
Old 05-07-2007, 08:06 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: dvd not loading
you may have disable autorun.Please enable it.Here is how you can do.
http://techhunt.org/xp/tips/how_to_e...unning_cd_roms
ravi_9793 is offline
Old 05-07-2007, 11:14 AM   #3 (permalink)
free as a bird
its already set to 1 , but still its not working.
vicky_l7 is offline
Old 05-07-2007, 03:11 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
does the same digit DVD/CD auto run on other sytem.Please check.
Old 05-07-2007, 09:26 PM   #5 (permalink)
free as a bird
yeah it run properly on the dvd burner.
vicky_l7 is offline
Old 05-07-2007, 11:07 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Do you have two drive in your system???
Old 05-07-2007, 11:14 PM   #7 (permalink)
I Sell Brains,Any Buyers?
pranavrules2007's Avatar
Some older versions of DVD-ROMS don't support auto booting the DVDs that you load into em. I had an older Compaq version of DVD ROM which had the same problem as yours. So rest assured, your computer is getting old..
Regards,
Pranav
-- I InventeD Microsoft, Gates Made it Famous --
Intel 975 XBX2
Intel Core2Duo 6600 @ 2.40 GHz
2 GB Transcend DDR2 667 MHz RAM
250 GB Western Digital SATA-II
Nvidia 7300LE 256 MB Graphics Card
pranavrules2007 is offline
os not loading rksingh Software Q&A 3 25-12-2006 07:45 PM
Delay in IE Loading rajat22 QnA (read only) 21 24-05-2006 10:21 PM
Loading Subtitles !!! Dipen01 QnA (read only) 4 22-03-2006 11:56 PM
Loading new software ! ! ! ax3 Software Q&A 5 13-10-2005 07:26 PM
Down loading web pages to PC nedun_cheran QnA (read only) 3 11-04-2005 09:52 AM
- by Krow
