Often uninstalling a program leaves empty folders in your drive that the uninstaller fails to remove. Over time these accumulate in your hard drive and clutters your drive. Even junk file cleaners like CCleaner doesn't remove these. The following two applications enable you to scan a drive or a folder recursively for empty folders. The application will then show all empty folders and you can select and delete the ones that you don't require.
Remove Empty Directories 2.1 (this one is freeware)
