Old 04-07-2007, 07:55 AM   #1 (permalink)
Exclamation 5.1 output........Please HELP ! ! !
Hi friends.....Recently i buyed a Videocon DVD player which supports 5.1 speakers...and also i buyed a Creative 5.1 speakers.......Well but the problem is when i burn a mp3 disc in Nero and play it in the videocon player...output is available only in two speakers !!!!....but when i played a original DVD [sony bmg "Rang De Basanti"]....it plays very well and output is available on all the speakers....so if it is the problem with writing the cd/dvd...Then please guide me how to write a cd/dvd to have output in all the speakers of 5.1...
zany is offline
Old 04-07-2007, 02:24 PM   #2 (permalink)
Default Re: 5.1 output........Please HELP ! ! !
its beacuse the songs u burn on ur cd were 2 channel sound they were not 5.1 songs so only 2 spakers appear to sound while others r quit to tell u most of the songs r 2 channel stereo
garefield is offline
Old 04-07-2007, 02:47 PM   #3 (permalink)
slugger's Avatar
AFAIK data in mp3 r encoded using 2 channels, bcos of which u r able 2 hear sound from only 2 speakers. ders simple no data 2 b rtransmitted 2 the other channels
as 4 ur DVD, it is bcos the audio has been encoded in 5.1 channels so you can hear a particular sound from dat particular speaker. each speakers has been alloted a dedicated audio stream
DAt is y u must have read in the various speaker reviews dat if u r into muzik u must buy a 2.1 speaker whereas if u r into moviez u must buy a 5.1 set
you cud try to encode ur songs in mp3 surround encoder
heres a little background
MP3 SX converts two-channel content into surround. MP3 SX achieves a stable localization of vocalists and solo instruments even off the sweet spot. Additionally, MP3 SX presents the feeling of envelopment by analyzing the ambience sounds already present in the stereo source. MP3 SX supports a seamless transition from stereo to surround sound.
slugger is offline
Old 04-07-2007, 06:52 PM   #4 (permalink)
Thank you ....... But none of the links work .... so please update them ....
zany is offline
Old 04-07-2007, 07:45 PM   #5 (permalink)
slugger's Avatar
der seems 2 b no problem
here r d direct links
MP3 Surround Encoder for creation of MP3 Surround files.
WinAmp PlugIn for MP3 Surround playback
assuming dat ur using Windoze
as 4 d background link ders no problem at all just click on it and read the info dat appears on the window dat opens
slugger is offline
Old 04-07-2007, 08:59 PM   #6 (permalink)
ayush_chh's Avatar
thanks a lot slugger for the links.....
@zany u also get some free dts files on net u can download them if u waana listen to 5.1 music...
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 04-07-2007, 11:50 PM   #7 (permalink)
Look if there's some option to upmix stereo files or sth in the DVD player's audio options.
sashijoseph is offline
Old 05-07-2007, 01:50 AM   #8 (permalink)
 Macboy
goobimama's Avatar
I'm not sure if your DVD player can upmix to 5.1, but depending on your soundcard software, it should upmix it to stereoX2, which duplicates the front two onto the rear...
I'm like a bird... :)
goobimama is offline
Old 05-07-2007, 07:14 AM   #9 (permalink)
Exclamation Re: 5.1 output........Please HELP ! ! !
ok thank you .... now it worked.....but i dint get much help.....will the output be available from all the 5 speakers if i write DVD AUDIO [NOT DVD MP3]...?
zany is offline
Old 06-07-2007, 07:06 AM   #10 (permalink)
slugger's Avatar
this sw is basically 4 mp3 encoding, but i'm not sure 'cause i don't have 5.1 so did not try encoding it, y don't u try it and keep us posted on d reults
slugger is offline
Old 09-07-2007, 04:19 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
superb @slugger ..........
i like 2 hear mp3 songs on my SONY system through WINAMP bt the output sound isnt THAT as it sounds in a HEADPHONE ......
any plugin 2 play these files @ same volume or increase output ???
i have even changed the wires connecting them ........ bt no use ......
ax3 is offline
Old 09-07-2007, 06:51 PM   #12 (permalink)
slugger's Avatar
u cud try out these DSP plugins in combination, 2 see how it works out
Enhancer
3D surround
DSP stacker
first install the DSP stacker and then from the window dat open up select Ehancer as the first plugin and #D surround as the second
works wonders if u listneing on headphones, but was not very satisfied with this combo's performance over speakers. try it out and keep us posted. d enhancer plugin also has a boost option to increase the volume
slugger is offline
Old 10-07-2007, 06:02 AM   #13 (permalink)
On the net
arnab2kool's Avatar
I have one good DSP plugin. works great if you can configure it well. Configuring the equalizer is just like 123. If you need it give me a pm containing your email address and I will give you the full version! And the equalizer settings that I am using in my computer, and it sounds excellent.
Thank you.
YOUTHS are not USELESS
YOUTHS are USED LESS
CORE 2 DUO USER
arnab2kool is offline
Old 10-07-2007, 11:14 AM   #14 (permalink)
ax3
ax3's Avatar
thanx @slugger .......... will try out .........
... W H O T ...
ax3 is offline
Old 10-07-2007, 12:59 PM   #15 (permalink)
yes,
1. You will need to upmix the "stereo mp3" to "mp3 surround" using the software given in the links and burn them on disc.
2 Burning a DVD-Audio will work, but not an optimal solution as then you will be upmixing the stereo mp3 to a very high bitrate, thus wasting space...
3. On the other note I think there should be some option in the DVD player to upmix the mp3 stereo output to 5.1 channels...
Let me know the Player Model which has capability to upmix stereo so I will take care when I buy the player...
dabster is offline
Old 17-07-2007, 08:26 AM   #16 (permalink)
Were you able to make it work...?
dabster is offline
Old 10-11-2008, 05:03 PM   #17 (permalink)
i am having sony home theater system i want that all my speakers work.prsently
my centre speker doesn't work. when i play original movie cd centre speker work's.i want that when i play mp3 songs my centre speaker should work.is there any software for this
karan_kapoorr is offline
Old 10-11-2008, 05:23 PM   #18 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: 5.1 output........Please HELP ! ! !
Originally Posted by slugger View Post
Mil gaya.....
Thanx.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 10-11-2008, 06:48 PM   #19 (permalink)
ajayritik's Avatar
^^ offtopic. I heard from my friend that we need a 5.1 sound card on the PC to get the 5.1 surround system Effect. But I see many friends of mine who dont have an additional sound card but still use 5.1 Speakers. Can someone give info on this?
ajayritik is offline
Old 10-11-2008, 10:01 PM   #20 (permalink)
Democracy is a myth
rhitwick's Avatar
^ now a days, many of the decent motherboards supply 5.1 sound card inbuilt .
So, nothing to be astonished of.
Old 10-11-2008, 11:10 PM   #21 (permalink)
please reply to query of mine
please reply
please help me in this situation
Last edited by karan_kapoorr; 10-11-2008 at 11:11 PM. Reason: Automerged Doublepost
Old 11-11-2008, 12:03 AM   #22 (permalink)
Democracy is a myth
rhitwick's Avatar
@Karan,
Just google the name of the motherboards ur frnds use, and u'll get to know that they all have at least 5.1 channel sound support (if built within 2yrs)
Old 11-11-2008, 11:49 PM   #23 (permalink)
@Karan
You may try using Matrix-Mixer.
Download here : http://sourceforge.net/project/showf...group_id=76433
Which soundcard are you using?
In your Sony system look for an option like 5.1 upmixing or 5.1 emulation or sth. like that.
Let there be music.....
Old 07-03-2009, 11:09 AM   #24 (permalink)
or just simply ffdshow decoder, which actually upmixes to 5.1 Channels.
dabster is offline
Old 07-03-2009, 10:32 PM   #25 (permalink)
ajayritik's Avatar
Dude you really bumped into an old thread!
@Karan,
Sorry for bumping into an old thread. I guesss you were replying to my query. I have the following motherboard. Would I have an inbuilt 5.1 sound card or would I need to buy a separate one?
Intel Desktop Board DG965RY
Old 07-03-2009, 10:46 PM   #26 (permalink)
Democracy is a myth
rhitwick's Avatar
As per this and this ur board supports 5.1 channel sound
Old 08-03-2009, 10:02 AM   #27 (permalink)
Many motherboards support 5.1 channel. I think it is because of the quality of the CDs
Bookworm is offline
Old 08-03-2009, 10:53 AM   #28 (permalink)
ajayritik's Avatar
What CDs? I didn't get you.
Old 08-03-2009, 11:01 AM   #29 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
guys why the music is not recorded in 5.1 channels
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 08-03-2009, 12:28 PM   #30 (permalink)
Some CDs are scratched. They don't run or don't give good sound quality. I faced the same thing in my PC two days back when I inserted a scratched CD.
Bookworm is offline
Output Screen In C++ ! BBThumbHealer Programming 7 08-03-2009 06:10 PM
Problem with TV output. slash_89 Hardware Q&A 1 03-05-2007 06:55 PM
Diff in Sound Output.. nitish_mythology Open Source 6 14-05-2006 09:20 PM
TV & DVI output problem god_of_frauds Hardware Q&A 3 25-12-2005 10:30 PM
C- Printing output godsownman QnA (read only) 4 21-09-2005 10:23 PM
- by Krow
