03-07-2007, 09:58 PM
Help Required regarding SMPS rating
comparison between the specification of Powersafe 500W silver and powersafe 400W GOLD also its available price in mumbai.
Whether i required a 500W or 400W for my system config of ASUS K8N4E DELUX with AMD 3000+,NVIDIA XFX 6200 GT ,Two SATA 200Gb, DVD writer TV tunnercard modem. I want to upgrade the gfx & procy in the future. so plz suggest the right SMPS for me to buy.
keep it cool
03-07-2007, 10:02 PM
Learner
Re: Help Required regarding SMPS rating
The 400W will run fine, but for upgrade, and any additional devices u might wanna use, I would suggest 500W, it's a good PSU.
04-07-2007, 06:28 PM
I WANT MORE FPS!!
I feel all these SMPS specs are overrated. I have a 288 Watt PSU. I got 2*512mb ddr2 , Pentium D 820 (power hungry) , ATI xpress200 motherboard, XFX 7600GT graphics card, 11 button 2000dpi laser USB mouse, 16x DVD-writer, 56k modem, Seagate Barracuda hard disk. I also use dual analog stick USB gamepad with vibration feedback, external Seagate hard disk and 5.1 speakers and onboard LAN connected to ADSL modem and of course a keyoard. My computer has been on 24*7 since 9 months and still no SMPS problem. Many of the online calculator say i need 400W minimum. Even my graphics card box says 400W minimum. My 288W is still doing fine.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
04-07-2007, 08:08 PM
Learner
They are overrated, they mention the max output, and they also mention the efficiency, usually 65-70% efficiency for local ones and upto 80% for very good ones, SMPS so basically there's a lot of difference in what it's rated and what u get.
A few SMPS in the past did not mention Max output but continuous output, which is a good thing for consumer, maybe urs is one of those SMPS, and maybe it has a good efficiency ratio too, in chich case, 288W is sufficient to power a good rig.
04-07-2007, 10:19 PM
I WANT MORE FPS!!
I didn't get you. What is max output, continuous output and efficiency?
Search this Thread |
