Old 27-02-2005, 04:00 PM   #1 (permalink)
hack expert's Avatar
Default iso images
i have linux os instalation in an iso image so can i directly burn it on a cd and install or else wat have i got to do
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 27-02-2005, 04:21 PM   #2 (permalink)
yup! u can always do tht! use nero burn image option to burn it on cd!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 27-02-2005, 04:33 PM   #3 (permalink)
Other than burning them , u can either extract the files from the iso via apps like iso buster , magic iso etc and run linux installation from hard disk drive itself . Else u can run installation directly from the iso itself . which distro u got anyway ? if ur new to linux , burning and learning is the best way . if u wanna try alternative ways and have fun too , try above steps . this might help
http://www.thinkdigit.com/forum/viewtopic.php?t=14097
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 27-02-2005, 05:50 PM   #4 (permalink)
open NERO and click Disc Images or Saved Project and then click ur iso image wherever it is located and then burn it
Shwetanshu Srivastava
shwetanshu is offline
Old 27-02-2005, 06:16 PM   #5 (permalink)
thanx guys for ur support
- by Krow
