How To Empty Dustbin?
I am having problem with emptying the dustbin in desktop though the files in the bin is gone but the icon shows it is full. I do not know whats wrong with this. Please suggest me regarding this matter.
in case ur Recycle Bin is really empty as u say [not dust bin, 4 gods sake]here wat u can do
right click on ue desktop and select the Properties option. den from d window dat opens up, click on the Desktop tab at the top. when the window opens click on d Customise Desktop button. There u will find a Restore default button. Click on it and then click OK. ur prob shud b solved
