Old 27-02-2005, 01:04 PM   #1 (permalink)
Default max payne on sp2
hi
ever since i installed max payne 1 on sp2 it doesnt work. wen i open it...da splash screen comes...den it closes n evrything returns 2 normal..no error messages n all
and my system requirements r way more dan needed no prob dere.
so wat do i do ?
even older games like carmageddon 2, south park, etc dont work. please help
ishaan is offline
Old 27-02-2005, 02:27 PM   #2 (permalink)
Ethan_Hunt's Avatar
Well just try updating with its latest patch
http://www.3drealms.com/max/downloads.html
Plus try this Just Simply add in the target line of your shortcut of max payne -skipstartup For exapmle : Target: "C:\Games\Max Payne\MaxPayne.exe" -skipstartup
not sure on this one though but Try deleting the "Movies" folder of Max Payne (keep it in Recycle bin i ya want) and then try
Plus i heard that it had sound comptibility probs with SP2....doubt it wont take anything set below 4.1 or 5.1 sound setup
V for Vendetta
Ethan_Hunt is offline
Old 28-02-2005, 12:40 AM   #3 (permalink)
It worked (-skipstartup)! Thanx!
An empire, 37 inches and growing...
DKant is offline
Old 28-02-2005, 11:29 AM   #4 (permalink)
Ethan_Hunt's Avatar
Default Re: max payne on sp2
well for this there could be compatiblity issues with winXP....the least u could try would be The win98 compatiblity changing.....Right click on .exe file>Properties>Compatibility>win98 and OK.
Or try latest updates for Xp and possibly patches for the games from thier official websites
@Dknat.....anytime mate....glad to help
V for Vendetta
Old 28-02-2005, 04:05 PM   #5 (permalink)
nope it still didnt work
i had already tried the compatibility thing also...no help
thanks anyways
ishaan is offline
Old 28-02-2005, 05:26 PM   #6 (permalink)
Ethan_Hunt's Avatar
here ishan try this for Fixing carmageddon 2 on XP
First download the V2.0 patch from here http://www.downseek.com/download/9695.asp or
http://www.actiontrip.com/link.phtml...h=carmageddon2
Then download the WinXP fix from here
http://www.sci.co.uk/games/downloads.../carma2_hw.zip
Just patch ur game with this
Also tell me the exact name of the south park game
i'll just look up for its compatibility patch
V for Vendetta
- by Krow
