Old 27-02-2005, 12:52 PM   #1 (permalink)
Default strange problem
i recently installed tweak xp pro and advanced xp tweak in my pc
.whenever i press ctrl+alt+del then instead of opening task manager window , a message appears "task manager has been disabled by your administrator". how can i correct this problem?
paul_007 is offline
Old 27-02-2005, 01:01 PM   #2 (permalink)
Ethan_Hunt's Avatar
Well paul mate try this link
http://windowsxp.mvps.org/Taskmanager_error.htm
http://techrepublic.com.com/5100-6270_11-1054840.html
Just round up on google and wil find some more tweaks
V for Vendetta
Ethan_Hunt is offline
Old 27-02-2005, 01:28 PM   #3 (permalink)
type gpedit.msc at RUN ... then look for this way :
User Configuration > Administrative Templates > System > Ctrl Alt Del Options ...
now in right panel :
Here U must find remove task manager option enabled .... disable it! & U r done !
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 27-02-2005, 05:39 PM   #4 (permalink)
Default thnx a lot
thnx both of u 4 reply
allwyndlima
yehmeriidhain
paul_007 is offline
Old 27-02-2005, 09:26 PM   #5 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Hey I have been facing a problem with my Task Manager. When I press Ctrl+Alt+Del, the task manager appears for a sec or two and then dissappears. Same happens when I type "regedit" in Run. What is happening? Please help.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 27-02-2005, 09:30 PM   #6 (permalink)
task manager error
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 28-02-2005, 11:33 AM   #7 (permalink)
Ethan_Hunt's Avatar
well possibility of a spyware or virus infection mate.....run a full system scan and find the possible causes....which OS are u using by the way?????
V for Vendetta
Old 28-02-2005, 01:38 PM   #8 (permalink)
Download Ad-Aware! SE personal edition from http://www.download.com/ do a full system scan remove all spywares! or watever Virus is there ...
& do run some other Anti-Virus too ... fine!
gud luck!
Old 28-02-2005, 08:56 PM   #9 (permalink)
I am running WinXP, Indian version, patched with all the updates that the Windows Update allows me to. I have AVG, Spybot S&D and Adaware installed and I regularly scan my PC with them. All have been updated with the latest definitions. I am stumped!
- by Krow
