Old 02-07-2007, 10:24 AM   #1 (permalink)
chitvan's Avatar
Angry help Plzzzzz
i have PC config
3.0Gz,512MB,intel945,
160GB SATA,
i m using Xp sp2 media centre
yesterday i have installed Nero 7.0 which come with DVD drive.
but there was some problem in it ,so i have remove it from Add/remove programme, & then i lost my DVD drive icon in my computer.
so i have restore system for 7 days back but not get solution.
i thing cd drive driver removed.
no any cd & auto run cd work, bootable cd working so thats not problem with hardware.
pllzz help,how can i get my DVd drive in mycomputer,i dont want install fresh.....
chitvan is offline
Old 02-07-2007, 04:07 PM   #2 (permalink)
slugger's Avatar
Default Re: help Plzzzzz
Soln1
u may want to try this. Since you say that the CDs r auto running. open windows explorer and type the drive letter and press enter
for example if ur rive had been assigned letter L, go to d address bar and type the following
L:\
and press enter, see what happens
Soln 2
Download TweakUI from here
http://www.download.com/3000-2341-2830963.html
Install it
then run it and click on the My Computer tab. From the list provided just check the box associated with d drive letter of your optical drive.
if it is already checked then you may want to uncheck it, then click on the [b]OK[/] button.Log off the and login again. Open TweakUI and now check the box associated with ur drive. Click [b]Apply[b/], then OK. If requred just log off and then login, u shud see ur drive letter back in the windows explorer
PS : plz be a little more clear with ur post title. it shud give d readers at least a fair idea of wat problem u r facing b4 they click on ur post
slugger is offline
Old 02-07-2007, 04:54 PM   #3 (permalink)
piyush gupta's Avatar
its windows registry problem wait fro Vishal he will give u a reg hack for this
piyush gupta is offline
Old 02-07-2007, 05:55 PM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Try this
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager.
4. Click the drive with the question mark next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action menu, click Scan for hardware changes.
http://www.host4cheap.org/
Sukhdeep Singh is offline
Guide me plzzzzz tehnogeek QnA (read only) 5 24-10-2006 12:22 PM
Nokia Pc Suite Not Detecting My 3230 Phone!! Plzzzzz Help Me*** kool Mobiles and Tablets 11 24-10-2006 10:26 AM
Total Newbie for LINUX:Plzzzzz help me out guys rakeshishere Open Source 66 09-09-2006 07:14 PM
Plzzzzz HELP me : Internet EXplorer problem yours_truly Software Q&A 12 19-11-2004 10:46 PM
- by Krow
