Old 01-07-2007, 12:55 PM   #1 (permalink)
Just Do It
Charley's Avatar
Question Dynamic IP to Static IP
I have a Dataone connection, with dynamic IP's. I need to use some software and that it specifically requires a static IP address.
Customer Care says they haven't static IP's for Home plans
What can I do ?
Charley is offline
Old 01-07-2007, 12:58 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Dynamic IP to Static IP
What can I do ?
Yes, you cannot do that on Home plans. You will have to get business plans
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 01-07-2007, 01:31 PM   #3 (permalink)
dadhwalprince's Avatar
Talking Re: Dynamic IP to Static IP
[QUOTE=achacko@dataone.in]
QUOTE]
BSNL's customer care dept. Oh my GOD can say anything ..
i want to discus one thing here , i have dataone running on my PC with Vista from last one month and i had got onr problem thn i called them up 8 times , can u imagine what those guys told me . thay said ": windows Vista doesn't support dataone "
i had told them the same but finally there is a problem with LAN card ?
Rankeshwar Singh Dadhwal
Consultant Engineer
dadhwalprince is offline
Old 01-07-2007, 07:11 PM   #4 (permalink)
slugger's Avatar
you must use dynamic DNS services like DynDNS
http://www.dyndns.com/services/dns/dyndns/
to be able to link dynamic IP to your computer erverytime
slugger is offline
Old 01-07-2007, 11:01 PM   #5 (permalink)
Is actually a real word..
Hmm try sluggers option, heard there was software outh there and he seems to found it. you can also set your IP addy is a Static (just remember that ISP's usually refresh their IP's every so often, so you may have to set reset the following options back to dynamic.
right click on your LAN conection, select properties, look for something that says TCP/IP select that and push propeties button it is setup for dynamic, select other radio button for Static. before you do that open a cmd window and type ipconfig /all (this will give you all the info you need to set up a static IP, should also show you when the ISP will want to refresh that IP) basically transfer approriate numbers to correct spots. provided you did it correctly you should now be runing on a static IP address!
Liggy is offline
Old 02-07-2007, 01:43 PM   #6 (permalink)
Just Do It
Charley's Avatar
liggy, will it remain static through out the day ?
Charley is offline
Old 02-07-2007, 02:10 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
I am in mumbai, Have a LAN Internet Connection with Static IP
can i make it dynamic?
satyamy is offline
Old 02-07-2007, 04:25 PM   #8 (permalink)
slugger's Avatar
AFAIK, it is not possible. ur IP is like ur postal address. a static IP is like d address 2 ur permanent residence. so will ur postal addrss change if the geographical location of your house does not.
similarly dynamic ip would mean the address of ur house if you keep moving from place to place
you cud try using one of the numerous web-based proxy servers available to hide ur true IP
slugger is offline
Old 02-07-2007, 08:57 PM   #9 (permalink)
Just Do It
Charley's Avatar
The thread is diverting from the topic.
Charley is offline
Old 02-07-2007, 10:18 PM   #10 (permalink)
it should remain static until u set it back. I was having problems with torrents so I changed my IP to static and the only time I need to change it is when The ISP renews their IP addy for me, so I just deafult it back then make sure I'm connected, then switch it back to static.
Liggy is offline
how to set up static IP with MTNL BB??? Ambar Software Q&A 5 12-06-2007 09:04 PM
Airtel BB Static or Dynamic jack// ani Broadband and DTH 9 01-05-2007 08:26 PM
Static Dsl. Fc6 Config=? The Unknown Open Source 26 09-03-2007 10:39 PM
Can I get a static IP address via dial up?? thilina QnA (read only) 7 25-09-2006 12:46 PM
static ip address sujeet2555 QnA (read only) 5 30-01-2006 05:13 PM
- by Krow
