Old 01-07-2007, 12:23 PM   #1 (permalink)
Thumbs down Enable Hibernate Features ?
When i try to enable a Hibernate features from cmd Command on Vista it will not works. My hibernate function was not there in control panel. Please help. See the attachment.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 01-07-2007, 12:55 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: Enable Hibernate Features ?
Post your hardware configuration & motherboard model
about.me/gxsaurav
gxsaurav is offline
Old 01-07-2007, 02:00 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Right-click on "Command Prompt" shortcut and select "Run as Administrator" and then try again.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-07-2007, 01:59 AM   #4 (permalink)
where is Command Prompt in vista, i just go to run and enter CMD for command promot, so how should i make a shortcut.
boosters is offline
Old 02-07-2007, 02:11 AM   #5 (permalink)
Microsoft MVP
Yep. If its not in ur programs menu, then u can create a shortcut to "cmd.exe" and right-click on it and select "Run as Administrator".
Old 02-07-2007, 02:16 AM   #6 (permalink)
gxsaurav's Avatar
If hibernation is supported then it defaults to Hibernation in start menu. Since it is now, I doubt if Hibernation is supported in that mother board
Do u see "Hibernation" written when u click on the arrow next to start menu's shut down & lock button.
about.me/gxsaurav
gxsaurav is offline
Old 02-07-2007, 03:45 PM   #7 (permalink)
yes i see the hibernation button on start menu , it also works some day but now i can't see any hibernation button on start menu, and also how to make a shortcut on a desktop cmd.exe. ???
boosters is offline
Old 02-07-2007, 03:56 PM   #8 (permalink)
gxsaurav's Avatar
Try this
Start -> run -> type CMD, if it gives a notification for UAC click ok
Type in DOS box
powercfg -h on
If this doesn't work try again with UAC turned off.
about.me/gxsaurav
gxsaurav is offline
Old 03-07-2007, 12:22 AM   #9 (permalink)
there is no notification comes for UAC , i also try to write these words "powercfg -h on" but same again you do not have permission. I am a administrator but what the problem, please help me.
boosters is offline
Old 03-07-2007, 12:42 AM   #10 (permalink)
gxsaurav's Avatar
If it says "You do not have permission" then your account is not set as Admin. To disable UAC
Start -> Run -> type in "msconfig"
it will launch the config tool and under tools is an option to enable and disable uac. Then reboot & reenter the command.
And post which motherboard u have.
about.me/gxsaurav
gxsaurav is offline
TUTORIAL: Enable HIBERNATE Button in Shutdown Dialog Box ! Vishal Gupta Tutorials 60 19-03-2008 12:37 AM
Where is hibernate?? uzair Software Q&A 10 21-03-2007 07:26 PM
how to do hibernate gau_pppu Hardware Q&A 6 21-01-2007 02:16 PM
Hibernate pritish_kul2 QnA (read only) 16 16-01-2007 10:56 PM
Hibernate champ_rock QnA (read only) 7 17-04-2006 07:31 PM
- by Krow
