Old 01-07-2007, 06:59 AM   #1 (permalink)
tukaibatman
Posts: n/a
Default pc doesn't detect my creative ZEN
i hv just got a creative ZEN Nano MP3 player about a month ago
when i connected it to my pc it says "the USB device has malfunctioned"
my pc is an intel PIV 2.0 on an asus 845gl mobo & onboard graphics
wht can be the problem. none of the ports are working
whereas on my papa's PC which is an intel 3.06 on intel 945g mobo it works fine
i can only gather tht my mp3 player hasn't gone bad
do i hv to upgrade my drivers or anything like that please help me
i even formatted my pc (got XP with SP2 & formatted the C: drive only) & reinstalled windows but it didn't help????
Old 01-07-2007, 07:42 AM   #2 (permalink)
vasanth.kingofthehill's Avatar
Default Re: pc doesn't detect my creative ZEN
Try attaching any other usb device to ur pc and see if tat works fine
“I'd rather be hated for hated for who I am, than loved for who I am not.” -Kurt cobain
vasanth.kingofthehill is offline
Old 01-07-2007, 07:54 AM   #3 (permalink)
tukaibatman
Posts: n/a
i don't have any other USB device!!!!!!!!
Old 01-07-2007, 08:36 AM   #4 (permalink)
Try borrowing a pen drive or sth from a friend.....it's only to confirm if your usb controller's fine.
Also check for driver issues in device manager's USB controller area.
sashijoseph is offline
Old 01-07-2007, 10:48 AM   #5 (permalink)
Make sure the wires of the Usb port are insterted correctly on the motherboard
iceeeeman is offline
Old 01-07-2007, 01:12 PM   #6 (permalink)
nishant_nms's Avatar
must be a fault in the usb port. There may be software problem too, for checking that insatll another OS and test for it
nishant_nms is offline
Old 02-07-2007, 05:32 AM   #7 (permalink)
tukaibatman
Posts: n/a
guys problem solved
just changed te USB port & it is working fine
can't detect HDD Ankit Agrawal Open Source 4 23-04-2007 09:28 PM
Why your PC can't detect 4GB RAM? blackpearl QnA (read only) 13 23-03-2007 06:24 PM
My Creative 24Bit creative sound card not working in windows vista.... selvamcbe Software Q&A 2 05-11-2006 12:11 PM
- by Krow
