Old 30-06-2007, 11:21 PM   #1 (permalink)
Norms Buster
Exclamation CD/DVD Lens Cleaners - Are they effective ?
CD lens cleaners - the CD-like devices that have a row of small brushes on the bottom of the disc. They're supposed to wipe the dust off of the CD player's laser lens and lessen skipping.
I've heard that these CD/DVD Lens Cleaners are bad. The brushes, especially on the cheaper models, can knock the sensitive laser out of alignment and this can only be remedied by a trip to a service professional.
So infact, is the CD/DVD Lens Cleaner "really" effective ?
VexByte is offline
Old 30-06-2007, 11:22 PM   #2 (permalink)
Default Re: CD/DVD Lens Cleaners - Are they effective ?
Definitely Yes.
They are effective.
Sarvothaman is offline
Old 01-07-2007, 12:25 AM   #3 (permalink)
gsmsikar's Avatar
yes ...
they are sometime effective ...
gsmsikar is offline
Old 01-07-2007, 12:49 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yes............
ravi_9793 is offline
Old 01-07-2007, 01:02 AM   #5 (permalink)
NP : Crysis
xbonez's Avatar
so, they won't spoil the lens, no?
xbonez is offline
Old 01-07-2007, 01:35 AM   #6 (permalink)
left this forum longback
praka123's Avatar
better buy some good brand made?
praka123 is offline
Old 01-07-2007, 11:50 AM   #7 (permalink)
piyush gupta's Avatar
Practically they are effective but not too much they clean your lens but very very short increase
piyush gupta is offline
Old 01-07-2007, 01:07 PM   #8 (permalink)
nishant_nms's Avatar
it's effective
nishant_nms is offline
Old 01-07-2007, 06:52 PM   #9 (permalink)
As Piysh said, they are effective to some extend. Until recently, I could get only cheap unknown brands. Few days back I got a Philips one for Rs.125/-. The MRP was Rs. 150.
BTW, are CD cleaners equally effective on DVD writers/players?
V.Prem Kumar
janitha is offline
Old 01-07-2007, 07:07 PM   #10 (permalink)
slugger's Avatar
IC CHIP had once written an article for cleaning ur optical drive
they'd given step-by-step instruction to open ur drive and clean ur lens and re-grease the tray drive.
i followed it once.
all u need is a little vaseline, cotton swab, detergent and a screw driver, definitley a lot cheaper than buying a lens cleaner and effectiveness guaranteed [personal exp]
slugger is offline
Old 01-07-2007, 09:57 PM   #11 (permalink)
i followed it once.
I have also done so once with a CD ROM, just to try it out. Once you get the knack of it, it is a simple 5 minute job and gets the thing done far better.
Just be careful in doing it.
Or almost any repairman will do it for Rs.100/- or even less.
V.Prem Kumar
janitha is offline
Old 02-07-2007, 02:56 PM   #12 (permalink)
Old is Gold
prem4u's Avatar
better to do own.....than taking lens cleaner...
prem4u is offline
Old 02-07-2007, 04:51 PM   #13 (permalink)
better go for new one drive as most effectively and perfect cleaning can increase ur lens life to 1-2 months and thats for clean CD still skratched CDs rarely it will read
Old 02-07-2007, 05:36 PM   #14 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
its risky-er 2 open ur drive ....... ok if ur drive is 2 old .......
not only chip bt DIGIT had also published an article abt cleanning drives ......
ax3 is offline
Shall I replace DVD Writer lens?? hard_rock Hardware Q&A 16 25-06-2009 12:36 AM
Are Registry cleaners worthwhile??? go4saket Tutorials 7 19-09-2007 05:36 PM
Registry Cleaners: Which one? rakesh-the gilli QnA (read only) 12 13-09-2006 12:58 AM
DVD Writer Lens Cleaner adorablesrini Hardware Q&A 16 09-03-2006 10:19 PM
Depth of Field Effect using Lens Blur Filter (Photoshop Tut) goobimama Tutorials 2 26-07-2005 11:34 PM
- by Krow
