Does any1 know how to design a basic remote control for pc so dat i can play any song or movie, increase or decrease its volume and so on .... just like we do with our tv . I wud love to hav an infrared remote, not a bluetooth one. Or is there any way in which i can use my Onida tv remote to control my pc Dat wud b absolutely wonderful
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
You can buy a Media Center PC remote or you can buy a Wireless Multimdia Keyboard but that would be heavy
Ah! one last thing, if you have a Pinnacle TV Turner.....like i have ...you can configure its remote. Each Key pressed on remote passes a Windows Shortcut so its possible that way....other tv turners aswell but i am nt sure
yes you can do it with any infrared remote, search for Rs.121 Remote for PC by venkateshwarang on the forum
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
search in market..U will get remote for ur PC.U can even use ur mobile phone as remote for ur PC.I have sony ericssion k750i which can be also used as remote for PC...but I havnt tried it yet.
If that tutorial file is not available for download, tell me, i have it and i will upload it.
There is sum prob with both rapidshare and megaupload links. I wud b grateful if u upload dat tutorial.
alright sumhow got the tutorial. will definitely try it out...... Thanx a lot everybody
Reason: Automerged Doublepost
Hey u said pinnacle tv tuner remote can also be configure for windows shortcuts even for Media Center and WMP 11 ?How sukhdeep
Search for Pinnacle Remote config file (profiles.ini). Most likely it would be
C:\Documents and Settings\All Users\Application Data\Pinnacle\Remoterm\Profiles
This file contains exactly what do to on a particular key press
