Old 29-06-2007, 08:22 PM   #1 (permalink)
Default changing ip!!!
i wana change my ip... is there any software for changing ip!!!... i am using Airtel GPRS. i have tried PCMesh Anonymous Web Surfing software. but its not working. it tells that an error or bug occured. please tell me a good software for changing ip.
prinz is offline
Old 29-06-2007, 08:49 PM   #2 (permalink)
What?
Ihatemyself's Avatar
Default Re: changing ip!!!
MOST CURRENT VERSIONS (best software first)
1. Hide the IP 2.1.1
2. IP Anonymyzer 3.3 build 37
3. IP hider 2.7
4. Hide My IP 1.9
5. Invisible Browsing 5
6. Anonymizer Anonymous Surfing 6.1
and many more (Hide the IP works 100%)
By the way why do u want to Hide IP bro ...Any good purposes
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
Ihatemyself is offline
Old 29-06-2007, 09:16 PM   #3 (permalink)
3. IP hider 2.7
4. Hide My IP 1.9
yea, buddy... i cant download anything from rapid share bcz of having static ip...
prinz is offline
Old 29-06-2007, 09:39 PM   #4 (permalink)
24online's Avatar
ok...
u have to use proxies.....or buy RS premium a/c....
**#(o)#**
24online is offline
Old 30-06-2007, 08:40 PM   #5 (permalink)
deepak.krishnan's Avatar
BTW are there any open source s/w for hiding the IP???
.dk
deepak.krishnan is offline
Old 03-07-2007, 02:46 AM   #6 (permalink)
On the net
arnab2kool's Avatar
Use the best software that I always use Hide My IP. Its the best, because when you change your ip thru any software like this it relays ur traffic thru another server, that results in a bit reduction in speed. HIDE MY IP is the same, but the speed reduction is a bit that doesnt puts any affect. I have searched for HIDE MY IP in rapidshares and even downloaded it, cause it connects to its company's server to check the serial number, and an official of that company personally verifies your software, then only you will be able to use it for full otherwise only 3 days demo. So I have purchased it. You also do that, costs only $29.
Thank you.
Well mate as far as I know and I have searched, I havent found any open source IP Hider. better buy one.
Thank you.
YOUTHS are not USELESS
YOUTHS are USED LESS
CORE 2 DUO USER
arnab2kool is offline
Old 03-07-2007, 12:48 PM   #7 (permalink)
slugger's Avatar
sum good FREE web-based proxy servers dat i've been using quite often [though i haven't used it 4 accessing RS]. Delay almost not noticeable
Anonymouse
http://anonymouse.org/anonwww.html
Proxify
http://proxify.com/
slugger is offline
changing IP address!!!!!!! amrit1 QnA (read only) 12 26-03-2006 09:06 AM
changing partitions. shashanktyagi1 Hardware Q&A 18 01-03-2006 11:43 AM
Changing the CPU Speed.... Please Help... vickymustdie CPU / Motherboards 1 08-08-2005 03:13 PM
Changing Faces NikhilVerma Tutorials 13 14-06-2005 12:14 AM
Changing the CAS latency of RAM???? yesh_1683 QnA (read only) 2 17-03-2005 06:58 PM
- by Krow
