Old 28-06-2007, 10:13 PM   #1 (permalink)
dadhwalprince's Avatar
Default Reply from 66.94.234.13: bytes=32 time=343ms TTL=50 ?
Ping 66.94.234.13
Can anybody explain this line , byte time and ttl
Rankeshwar Singh Dadhwal
Consultant Engineer
dadhwalprince is offline
Old 28-06-2007, 10:25 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Reply from 66.94.234.13: bytes=32 time=343ms TTL=50 ?
Bytes is the amount of data your ping sent and received back.
TTL is the Time To Live of the PING, aka, the amount of times it must go on hopping before it must be dropped or returned back to you.
Time is of course, the time taken for the reply packet to come after you send an echo request via PING.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 28-06-2007, 10:31 PM   #3 (permalink)
club_pranay's Avatar
TTL= Time To Live - A field in the Internet Protocol header which indicates how many more hops this packet should be allowed to make before being discarded or returned.(time before reporting "request timed out")
Time= time in milli secs for the data reply
bytes = size of the data packet
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 29-06-2007, 08:20 AM   #4 (permalink)
Could you explain TTL with an example ?
Consultant Engineer
Bytes that u have never heard before. (Must read for tech savvy) Gigacore Tutorials 3 28-04-2007 09:24 AM
How to format a FAT filesystem with lesser bytes per sector? alsiladka Hardware Q&A 2 22-02-2007 07:05 PM
missing bytes hemanth85 Hardware Q&A 13 16-11-2006 10:33 PM
bits and bytes HELP PLZ!!! mediator QnA (read only) 10 28-08-2005 05:31 PM
your reply-please. kumarn_2004 QnA (read only) 7 21-02-2005 02:38 PM
- by Krow
