^^ thnx for ur sweet comments.
@*GandaBerunda* (I wonder what does it mean?
1. U should be good in graphics so that u can create BITMAPs for themes.
2. U can use Resource hacker or Style Builder to create themes. Second one will be easier.
3. If u r modifying a theme, then u can use it for ur personal use. Don't release or share it with others until u get permissions from the theme creator.
4. If u use ur own images in theme and create it from scratch, then go ahead and release it.
