Old 26-02-2005, 09:09 AM   #1 (permalink)
darklord's Avatar
Default RAM Inquiry,URGENT !!!!!!!!!!!
Hey Guys,
I need some help here.
I plan to buy some new RAM for me.
I am interested in-
1] Corsair XMS series
2] Kingston HyperX Series
3] Crucial Ballistix
4] PDP Patriot
i want in DDR and not DDR2.
Is any of these available in India ?
I would like to know if yes,then from whom ?
Please let me know asap.
Thanks,
Darky
darklord is offline
Old 26-02-2005, 09:17 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
Corsair XMS are available in Prime ABGB
they were reviewed in CHIP 3-4 months ago and the supplier name had PRIME ABGB for the credits
so y do u wanna buy it anyways
Sourabh is offline
Old 26-02-2005, 09:24 AM   #3 (permalink)
darklord's Avatar
the SMPS and the RAM is the weakest Link in my system.So wanna upgrade it.
I know Prime ABGB cery well, will ask Gulbir.
darklord is offline
Old 26-02-2005, 02:15 PM   #4 (permalink)
Hey Darky, by upgrading u mean u gonna sell this Transcend & get a stick of 1Gb CorsairXMS??
I dont think its worth it,coz the XMS costs nearly 2.5times the normal Corsair!!
U ought to get a higher Perf. gain by buying ANOTHER stick of 1Gb Transcend.
Unless u want the XMS solely for OC/ing the CPU,in which case u r still better off upgrading the CPU to a higher Ghz stepping....
Just my 2cents...
delhibhai1000 is offline
Old 26-02-2005, 05:23 PM   #5 (permalink)
darky i suggest if you can you test out the rams on your board before buying it since i heard that the asus a8n-sli can do a max of 240fsb with the memory at 1:1 , not too sure though but i have the same problem with my a8v (via chipset) if i use a divider i'm able to reach a very high htt but i cant overclock with the ram in sync even though its capable of reaching high htt
bottle is offline
Old 26-02-2005, 06:54 PM   #6 (permalink)
darklord's Avatar
Hmmm.Bottle so should i go for it or no?
I am very confused now.
As it is i am not gonna buy 1GB but 512 MB of that RAM.
So what do you say ? Add another 1 GB or buy 512 MB of High Performance RAM.
darklord is offline
Old 26-02-2005, 07:09 PM   #7 (permalink)
request to mention the warranty on diff modules too .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 26-02-2005, 08:06 PM   #8 (permalink)
hey
so u think LL ramz better than value 1 .
just read this post by zebo at anandtech/forums n u all will no there aint much ****ing diff btw the 2 -
http://forums.anandtech.com/messagev...&enterthread=y
n do read the whole of it
mamba is offline
Old 26-02-2005, 10:03 PM   #9 (permalink)
how high does your transcend ram overclock at the moment ? getting premium ram to run at 240fsb at low latencies will definitely give you a boost but its up to you to decide if its worth it or not
2gb seems a bit pointless in todays world.. might actually be slower in some cases
bottle is offline
Old 26-02-2005, 10:30 PM   #10 (permalink)
KHUBBU's Avatar
Great!
The heavyweights from tech-arena are here. wow.
Well, i have one question. I have redued my ram latencies to 2-3-3-5. In sisoft sandra I can touch 3997. I have 128x2 ddr 400 ram, 865 GV mobo. When I increases the fsb 4 points it crossed 4000 mark upto 4102.
The cpu was running at 2.85 GHz from original 2.8 GHz.
Is there any other way to increase memory bandwith. The 865 PE reference chipset in sandra shows bandwith around 5000.
Brand new Day!
KHUBBU is offline
Old 27-02-2005, 05:21 AM   #11 (permalink)
it does seem a bit less , i get a memory bandwidth score of 3300 for my ram thats running at 150Mhz
can you use a diagnostic utility like cpu-z to confirm that you are running in dual channel mode ?
another explanation could be that there are too many process running in the background hogging your memory and affecting your score
bottle is offline
Old 27-02-2005, 10:28 AM   #12 (permalink)
darklord's Avatar
My Transcend can go upto 440 MHz MAX.Not beyond that.
This too at relaxed timings.
its up to you to decide if its worth it or not-------> This question arises if i am able to get those RAM sticks.Then comes the price then the question of being worth.No one is answering my main question,AVAILABILITY
2gb seems a bit pointless in todays world.. might actually be slower in some cases-----> I too feel the same way,this proposal is scrapped.
darklord is offline
Old 27-02-2005, 12:30 PM   #13 (permalink)
Kingston HyperX & Corsair TwinX r avlbl locally...
Nearly the same prices for HyperX....
Old 27-02-2005, 05:24 PM   #14 (permalink)
darklord's Avatar
In that Table ,
under XMS it says,
TwinX512-3200 256 MB [size] 9200/-
what does it mean? this is rate for 512MB or 256 MB ?
i am confused. :roll:
Also what all brands of RAM are available there ?
Please provide this info man,i need it desperately.
darklord is offline
Old 27-02-2005, 06:08 PM   #15 (permalink)
MAN !!!!!! didnt u ppl read the link i gave . y run after extra costly ram if it aint worth . i suggest do read zebo's post at .....
mamba is offline
Old 27-02-2005, 06:42 PM   #16 (permalink)
@DARKY: 2*256mB modules...
these r the RAMs avlbl 4 sale:;
Corsair
Kingston
Twinmos
*Original* HYNIX
Zion with Hynix chips
Micron
Old 27-02-2005, 11:05 PM   #17 (permalink)
darklord's Avatar
thanks pal
darklord is offline
- by gforz
- by gohan89
