Old 26-02-2005, 08:56 AM   #1 (permalink)
Default STUNNED ME I AM WORRIED A LOT PLZ HELP ME....!!!!!!!!!
I don't know what is the problem but the .jpg files are getting blocked in my web browser. (both Fire Fox and IE ) I am worried a lot tommorow i have a project to be submitted and the problem is like this. Plzzzzzz plz help me this the project of my life help me out
U CAN\'T STOP WIZARDS
wizard_with_a_wand is offline
Old 26-02-2005, 09:10 AM   #2 (permalink)
kl_ravi's Avatar
Is it happening for *.JPG or *.GIF also ?? If *.GIF is also not displayed, the check your browser settings.
In internet explorer, Click Tools > Internet options, and in the Advanced tab, scroll down to multimedia section. an check "Show Pictures" field.
Which is the default program to handle jpg and gif files in your system ?
Just in case, if you double click and can't open the jpg files altgether, then you need to re-install Internet explorer and also try to upgrade to Service pack 1.
kl_ravi is offline
Old 26-02-2005, 09:32 AM   #3 (permalink)
i am able to open .jpg files normally when coming to web browsers i am not able to c them. even the .gif files
Old 26-02-2005, 10:07 AM   #4 (permalink)
kl_ravi's Avatar
Did you check your browser settings ?
If they seem to be ok, follow the links below....
http://support.microsoft.com/?kbid=283807
http://support.microsoft.com/?kbid=307239
kl_ravi is offline
Old 26-02-2005, 11:35 AM   #5 (permalink)
hack expert's Avatar
do one thing use some other browser temporarily if it is dat urgent it will display every thing .jpg n all there is some proble with ur setting
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 26-02-2005, 12:05 PM   #6 (permalink)
If u use some firewall ry keeping its program control to low and try
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 26-02-2005, 12:47 PM   #7 (permalink)
godsownman's Avatar
It looks like some settings only that have been knocked of accidentally as kl_ravi said try that or unistall firefox and retry installing it that should solve the problem.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 26-02-2005, 01:15 PM   #8 (permalink)
try reinstalling ur browsers! ... it might be tht accidently U or somone else made some changes in settings of browser! .. try reinstalling it
gud luck!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 27-02-2005, 12:33 AM   #9 (permalink)
swatkat's Avatar
try this in FireFox, Go to Tools>Options>Web Features, here select/check the option "Load Images"......
also, which software is the default app. for jpg/gif files in ur system....
http://swatrant.blogspot.com/
swatkat is offline
Old 08-03-2009, 10:37 AM   #10 (permalink)
Default Re: STUNNED ME I AM WORRIED A LOT PLZ HELP ME....!!!!!!!!!
Do one thing in Firefox, go to Tools- - Options. There go to content tab and Load images automatically is selected. If selected then go to the exceptions tab and check if the website you want to open is blocked. If doesn't work. Reinstall the browser.
Bookworm is offline
Old 08-03-2009, 12:48 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
It's "Ad Block Plus" most probably.
Disable it from "AddOns".
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 08-03-2009, 12:55 PM   #12 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
try installing some other browser like opera and chrome see if the problem persists
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 08-03-2009, 02:17 PM   #13 (permalink)
AFK
thewisecrab's Avatar
Its a 4 year old bump
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
- by gforz
- by gohan89
