Results 1 to 2 of 2
  1. #1
    Jul 2004
    Thottakad,Kottayam,Kerala
    Default Direct sound output v2.2.10error
    dear friends,
    recently i am facing some problem in using windows media player.i am not able to pay any songs. iam using win xp sp2.
    following is the error message
    direct sound out put v2.2.10 error
    Bad Direct Sound driver.please install proper driver or select another device in configuration.
    error code.88780078
    i had tried to uninstall the sound driver and reinstall the same.it works properly.but after retarting,same error appears.
    can someone help me?
  2. #2
    Human Spambot swatkat's Avatar
    Mar 2004
    India
    check that "Windows Audio" service is enabled in the Windows XP Services. Go to Start>Run and type services.msc and press Enter, and check the service name Windows Audio service ( process name will be AudioSrv in XPHome and svchost.exe -k netsvcs in XPPro ), the status should be Automatic.........
    try reinstalling DirectX....
    http://www.microsoft.com/windows/dir...ds/default.asp
    also give details about ur motherboard, soundcard etc....some soundcards need to have SP2 patch for them to work properly....
    also, for winamp u can do this overcome this problem, change the Output Plugin ( in Preferences ) to WaveOut......
    http://swatrant.blogspot.com/
  1. [SOLVED] Help Regarding PC Sound output !
    By TheMost in forum Audio
    Last Post: 11-08-2011, 04:30 PM
  2. low sound output in laptop
    By rsk11584 in forum Laptops and Netbooks
    Last Post: 07-02-2011, 03:39 AM
  3. Replies: 1
    Last Post: 17-03-2007, 09:42 AM
  4. No sound output <Strange>
    By gearShifts in forum Hardware Q&A
    Last Post: 01-02-2007, 10:29 PM
  5. Problem in DVD sound output
    By udhaybhavan in forum QnA (read only)
    Last Post: 06-01-2005, 11:07 AM
