hi ,
i have a mtnl broadband conn. with t-kd 318 eui router, how can i port forward my router?
i use bitcomet, and it always shows a yellow light saying blocked (my ip address), wot does it mean?
also anyways to speed up torrent downloads will be very appreciated.
amit
i'm not sure abut port forwarding, someone else might give u a detailed tutorial on that,
i used to earlier use utorrent and got speeds between 18-20kBps on my 256kbps line. after a couple of weeks, i started getting speeds under 10kBps even with torrents with excellent health. i then started using bitlord. its pretty gud. i constantly get speeds above 25kBps and with torrents with goo health i get avg download speeds of as much as 30kBps
find the help of ur router number or if there is a manual that came with it
then go to the ip address that it says to configure something like 127.0.0.0 in internet explorer or mozilla firefox whatever
it will show router page u can configure router there goodl luck
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
