Old 27-06-2007, 10:41 PM   #1 (permalink)
CA50's Avatar
Lightbulb Live Cd
is It Possible To Create A Live Windows Xp Cd, Like Linux. If Yes Plz Tell Me
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 27-06-2007, 10:47 PM   #2 (permalink)
sam_1710's Avatar
Default Re: Live Cd
yes.. use BartPE
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
sam_1710 is offline
Old 27-06-2007, 10:54 PM   #3 (permalink)
CA50's Avatar
Default Re: Live Cd
Originally Posted by sam_1710
yes.. use BartPE
Thanks , will u tell the procedure. I hv got win xp sp2 geniune disc
| Nokia 2700c |
CA50 is offline
Old 28-06-2007, 11:51 AM   #4 (permalink)
The Researcher
Default Re: Live Cd
I think with BartPE one can create only a live cd which will just allow you to browse your hard disk. No ther software will be there. I have got one, that is why I am writing. If you are successful, Please do post the procedure here. May be the mods will make it a sticky because so many of us want such a CD.
Ramakrishnan is offline
Old 28-06-2007, 11:56 AM   #5 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Smile Re: Live Cd
^^You can include softwares in bart pe like image viewers ,anti virus,backup softs and many more .only need to go through the plugins given in the support sites.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 28-06-2007, 12:31 PM   #6 (permalink)
sam_1710's Avatar
Default Re: Live Cd
this will help u : http://www.dedoimedo.com/computers/livecd.html
sam_1710 is offline
Old 29-06-2007, 09:00 PM   #7 (permalink)
CA50's Avatar
Default Re: Live Cd
Well i tried to edit the plugins but i didn`t succeed. plz post the procedure if u know the way
| Nokia 2700c |
CA50 is offline
Old 01-07-2007, 11:37 PM   #8 (permalink)
CA50's Avatar
Default Re: Live Cd
Hi pals, i recently suceeded to add VLC player in the live cd. After creating the live cd i opened it using Magic ISo and added the whole folder named "VLC" 4m my HDD. After booting 4m the cd video files plays well but there is no sound. I think this is due to my audio drivers. plz suggest how to add my drivers
| Nokia 2700c |
CA50 is offline
Old 01-07-2007, 11:46 PM   #9 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Live Cd
First download the plugin for the program u wish to include in cd,read the help file that u get with the plugin.
, and a easy way to test ur cd before u actually burn the cd is given in the below link
http://www.bootcd.us/PEBuilder_tutorial.php
zyberboy is offline
Old 02-07-2007, 12:32 PM   #10 (permalink)
The Researcher
Default Re: Live Cd
Is all plug-ins for all the programmes that we use available? Is plug-in available for ms-office, antivirus packages, acronis true image, tally etc?
Old 02-07-2007, 01:29 PM   #11 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Smile Re: Live Cd
^^Not all but ter are many, u can see urself here http://www.bootcd.us/BartPE_Plugins_Repository.php
zyberboy is offline
Windows Live Mail & Windows Live Messenger Problems adit_sen Software Q&A 2 22-03-2006 12:46 AM
Live CD starscream Open Source 3 06-09-2005 10:29 PM
live cd vignesh QnA (read only) 4 27-01-2005 05:00 PM
- by gohan89
