27-06-2007, 09:12 AM
pen drive as floppy
hello
is there any way to use usb pen drive as floppy drive specially when booting
as for cd may be emulated as floppy when using it 98 startup disk
plz let me know
all i want to do is back my xp installation & floppy is asked at the end
since they r not much durable any solution
& i cant convert my c: from ntfs to fat32 using partition magic 8
a task is scheduled for the purpose but nothing happens
27-06-2007, 10:27 AM
Host4Cheap.org
Re: pen drive as floppy
Originally Posted by liquid_snake
hello
plz let me know
1. You can make Pen Drive Bootable but you cannot emulate it as Floopy AFAIK.
2. Download Ultimate Boot CD or Hiren Disk. Use thse Boot Disks and try to convert using Dos based Partition Managers
http://www.host4cheap.org/
27-06-2007, 04:25 PM
"Technologic"
I think a certain Linux distro(can't remember which one), stored on a pen drive, can work similar to a bootable startup disk. Dunno if something similar can be done with any versions of Windows.
 One great use of words is to hide our thoughts.
27-06-2007, 05:24 PM
Host4Cheap.org
Yes, like i said....you can make Pen Drive bootable with Dos, Linux and there is Warez version of XP for Bootable USB
27-06-2007, 07:05 PM
God of Mistakes...
yes, but believe me they don't work.
16-07-2007, 07:47 PM
hi sukhdeep
plz tell me hoe to make the pen drive bootable in dos
will be very thankful to u
16-07-2007, 08:54 PM
Host4Cheap.org
hi sukhdeep
Download here : http://www.mediafire.com/?7wwkitwd7cr
16-07-2007, 10:42 PM
hey buddy it said windows format utility. wat does it do?
16-07-2007, 10:44 PM
It depends on your mobo. Some mobos support pen drive booting and some don't. Refer to ur manual.
KDE on ArchLinux
18-07-2007, 11:44 AM
thank man hope that wd work
18-07-2007, 02:21 PM
RU talking 2 me?
KDE on ArchLinux
18-07-2007, 03:02 PM
King of my own Castle
It does !  if done properly !
24-08-2007, 05:09 PM
That worked & it was fabulous
thanks a lot
one more thing
now a days floppies are hard to be kept for long so use a image creator to backup ur floppy
any way thanks
24-08-2007, 06:21 PM
Host4Cheap.org
No problem bro, You seem to be busy guy......reply after months
Search this Thread |
