Old 26-06-2007, 03:09 PM   #1 (permalink)
Exclamation ram density
does ne1 hv ne idea on ram density??
will it pose ne compatibility threat with certain motherboards??
slyfox is offline
Old 27-06-2007, 08:46 AM   #2 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: ram density
does ram has density also???
the.kaushik is offline
Old 27-06-2007, 02:14 PM   #3 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Ram Density ????????
n00b forever...
~Phenom~ is offline
Old 27-06-2007, 02:17 PM   #4 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Phisix??? again?
bhushan05d251 is offline
Old 27-06-2007, 02:27 PM   #5 (permalink)
yya sumthing like 64Meg X64 or 128Meg X128
slyfox is offline
Old 05-07-2007, 10:58 PM   #6 (permalink)
I Sell Brains,Any Buyers?
pranavrules2007's Avatar
Exclamation Re: ram density
Unlike conventional RAM chip technologies, in MRAM data is not stored as electric charge or current flows, but by magnetic storage elements. The elements are formed from two ferromagnetic plates, each of which can hold a magnetic field, separated by a thin insulating layer. One of the two plates is a permanent magnet set to a particular polarity, the other's field will change to match that of an external field. A memory device is built from a grid of such "cells".
Reading is accomplished by measuring the electrical resistance of the cell. A particular cell is (typically) selected by powering an associated transistor, which switches current from a supply line through the cell to ground. Due to the magnetic tunnel effect, the electrical resistance of the cell changes due to the orientation of the fields in the two plates. By measuring the resulting current, the resistance inside any particular cell can be determined, and from this the polarity of the writable plate. Typically if the two plates have the same polarity this is considered to mean "0", while if the two plates are of opposite polarity the resistance will be higher and this means "1".
Data is written to the cells using a variety of means. In the simplest, each cell lies between a pair of write lines arranged at right angles to each other, above and below the cell. When current is passed through them, an induced magnetic field is created at the junction, which the writable plate picks up. This pattern of operation is similar to core memory, a system commonly used in the 1960s. This approach requires a fairly substantial current to generate the field, however, which makes it less interesting for low-power uses, one of MRAM's primary disadvantages. Additionally, as the device is scaled down in size, there comes a time when the induced field overlaps adjacent cells over a small area, leading to potential false writes. This problem, the half-select (or write disturb) problem, appears to set a fairly large size for this type of cell. One experimental solution to this problem was to use circular domains written and read using the giant magnetoresistive effect, but it appears this line of research is no longer active.
Another approach, the toggle mode, uses a multi-step write with a modified multi-layer cell. The cell is modified to contain an "artificial antiferromagnet" where the magnetic orientation alternates back and forth across the surface, with both the pinned and free layers consisting of multi-layer stacks isolated by a thin "coupling layer". The resulting layers have only two stable states, which can be toggled from one to the other by timing the write current in the two lines so one is slightly delayed, thereby "rotating" the field. Any voltage less than the full write level actually increases its resistance to flipping. That means that other cells located along one of the write lines will not suffer from the half-select problem, allowing for smaller cell sizes.
A newer technique, spin-torque-transfer (STT) or Spin Transfer Switching, uses spin-aligned ("polarized") electrons to directly torque the domains. Specifically, if the electrons flowing into a layer have to change their spin, this will develop a torque that will be transferred to the nearby layer. This lowers the amount of current needed to write the cells, making it about the same as the read process[1]. There are concerns that the "classic" type of MRAM cell will have difficulty at high densities due to the amount of current needed during writes, a problem STT avoids. For this reason, the STT proponents expect the technique to be used for devices of 65 nm and smaller. The downside is that, at present, STT needs to switch more current through the control transistor than conventional MRAM, requiring a larger transistor, and the need to maintain the spin coherence. Overall, however, the STT requires much less write current than conventional or toggle MRAM.
The main determinant of a memory system's cost is the density of the components used to make it up. Smaller components, and less of them, means that more "cells" can be packed onto a single chip, which in turn means more can be produced at once from a single silicon wafer. This improves yield, which is directly related to cost.
DRAM uses small capacitors as a memory element, wires to carry current to and from it, and a transistor to control it – referred to as a "1T1C" cell. Capacitors basically consist of two small metal plates separated by a thin insulator, a single element that can be built as small as the current fabrication technology allows. This makes DRAM the highest density RAM currently available, and thus the least expensive, which is why it is used for the majority of RAM found in a computer.
MRAM is physically similar to DRAM in makeup, although often does not require a transistor for the write operation. However, as mentioned above, the most basic MRAM cell suffers from the half-select problem, which limits cell sizes to around 180 nm or more. Toggle-mode MRAM offers a much smaller size before this becomes a problem, apparently around 90 nm[2]., the same size as most current DRAM products. To be worth putting into wide production, however, it is generally believed that MRAM will have to move to the 65 nm size of the most advanced memory devices, which will require the use of STT.
Regards,
Pranav
-- I InventeD Microsoft, Gates Made it Famous --
Intel 975 XBX2
Intel Core2Duo 6600 @ 2.40 GHz
2 GB Transcend DDR2 667 MHz RAM
250 GB Western Digital SATA-II
Nvidia 7300LE 256 MB Graphics Card
pranavrules2007 is offline
Water + Nanoelectronics = Super Density stoage Devices dharmeshhtailor Technology News 2 02-05-2006 11:49 AM
Seagate 7200.9 160GB: The Highest Platter Density to Date! jamyang312 QnA (read only) 4 09-02-2006 08:57 AM
- by gohan89
