Old 26-06-2007, 09:39 AM   #1 (permalink)
pritish_kul2's Avatar
Default AN errOR
It is as follows -
pritish_kul2 is offline
Old 27-06-2007, 12:14 AM   #2 (permalink)
Is actually a real word..
Default Re: AN errOR
I suppose you get this at starup. msconfig --> disable any office startup/services. might be crapware also, so run an AV scan, try ewido.net online scanner, or if you have a scanner run it.
Liggy is offline
Old 27-06-2007, 09:40 AM   #3 (permalink)
no when i open a folder, it comes
Old 28-06-2007, 12:38 AM   #4 (permalink)
did your try to got to www.ewido.net and click on the online scan, I'm thinking it maybe a form of malware, even though a quick google shows it is a legit ms dll. can never be to sure!
now you said it only happens when you open a folder. is that any folder? or an office document?
Liggy is offline
Old 28-06-2007, 09:55 AM   #5 (permalink)
any folder
Old 01-07-2007, 08:10 PM   #6 (permalink)
you have run crapware scanners, sounds like it is a result of either malware, or an update (graphics or other driver, or windows update)
Liggy is offline
Old 02-07-2007, 05:04 PM   #7 (permalink)
piyush gupta's Avatar
Can u post your hijack this log file here.
piyush gupta is offline
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
error while trying to retrive text for error ORA-12203 vikasg03 Software Q&A 1 14-11-2005 02:48 PM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
- by gohan89
