Old 25-06-2007, 10:03 AM   #1 (permalink)
pritish_kul2's Avatar
Default What is virtual memory?
What is this? i have over 2.0 gb free
pritish_kul2 is offline
Old 25-06-2007, 10:12 AM   #2 (permalink)
shashank4u's Avatar
Default Re: What is virtual memory?
This is system memory that is simulated by the hard drive. When all the RAM is being used (for example if there are many programs open at the same time) the computer will swap data to the hard drive and back to give the impression that there is slightly more memory.
you can find more here
http://www.google.co.in/search?q=def...ient=firefox-a
to increase your Virtual memory
right click my computer
go to advanced tab click settings
again go to advanced
check out virtual memory ..
increase your page file size there to 1.5 times your RAM ..
you can set up as large as you want ...but 1.5 to 3 times the size of RAM is what you should opt for.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 25-06-2007, 06:39 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
It is pretty similar to swap partition in Linux!
Whenever ur RAM becomes overloaded, it swaps data from RAM to virtual memory & after RAM becomes free, it reallocate it by data from virtual memory.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 25-06-2007, 06:53 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
scroll down
search before you start a thread.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Virtual memory LOW :( (help) tinku dhar Hardware Q&A 26 25-02-2007 03:51 AM
Virtual Memory s18000rpm Software Q&A 18 16-02-2007 12:42 AM
Virtual Memory!! gannu_rox Software Q&A 12 24-08-2006 09:48 PM
virtual memory is low ? mkmkmk QnA (read only) 7 19-06-2006 09:03 PM
virtual memory too low!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! alaap_anujan QnA (read only) 1 11-11-2005 06:10 PM
- by gohan89
