Old 25-06-2007, 01:10 AM   #1 (permalink)
asif1231's Avatar
Question pc crashing
while playing games like rise of legends and company of heroes the screen freezes with a screaching sound and i have to restart the system, and after reboot it says ''system recovered from a sereous problem'' i have 1.2 gb of ddr ram and 7600gs xfx card pls help.....
love life
asif1231 is offline
Old 25-06-2007, 08:55 AM   #2 (permalink)
Is actually a real word..
Default Re: pc crashing
turn off auto restart and then wait for BSOD then google (or MS KB) error code.
what is ur CPU and PSU?
Liggy is offline
Old 25-06-2007, 09:58 AM   #3 (permalink)
shashank4u's Avatar
upgrade your graphics card drivers to the latest one ..also upgrade your chipset drivers of the Mobo..
and try running games at the minimum settings.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 25-06-2007, 07:53 PM   #4 (permalink)
the same thing happens wit me.but i aint doin anythin when it happens.even while listening to music in winamp wit no plugins and wave out output plugin.The PC just hangs with a sharp piercing sound and i hav to reset.
I use P3 1.0Ghz 256MB ram single module.and creative es1781soundcard
If you can't beat your computer at chess, try kickboxing.
vutonium is offline
Old 25-06-2007, 08:39 PM   #5 (permalink)
Vutonium your issue might be low RAM. what other progs do you have running on your sys. do you have a third party firewall/AntiVirus. run a AV scan.
Liggy is offline
Old 25-06-2007, 08:42 PM   #6 (permalink)
!FREEWARES!
Akshay's Avatar
@vutonium
Ur prb seems to b coz of low hardware resources.
Dont 4get to update/reinstall ur soundcard drivers too.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 25-06-2007, 09:13 PM   #7 (permalink)
You may want to check the following.
Your cpu and gpu temperatures.
Your psu...your stock psu may be failing you
Ram...swap with a friend's etc.
sashijoseph is offline
Old 26-06-2007, 12:11 AM   #8 (permalink)
asif1231's Avatar
MY cpu is amd 3000 and mobo is msi i use 1.2 gb transend ram and generaly graphic card temp is around 65 to70 after playing games i have updated the drivers , i suppose i have fairly good hardware,no virus evything is ok except while playing game, i have played high end games before without difficulty
love life
asif1231 is offline
Old 26-06-2007, 09:17 AM   #9 (permalink)
which graphics card is it?
Old 26-06-2007, 03:42 PM   #10 (permalink)
asif1231's Avatar
n vidia xfx 7600 gs
love life
asif1231 is offline
Old 26-06-2007, 04:21 PM   #11 (permalink)
Always Fresh!
shri's Avatar
I'm facing a similar problem. My PC config is
AMD64 3000+
ASUS A8N-E
512MB Dynet Ram
XFX nVidia 6600 256MB graphics card
I've tried reinstalling windows. I have the latest graphics and motherboard drivers installed. The system temperature is within limits. No viruses. While playing games like NFS carbon and most wanted and some fps, the screen freezes all of a sudden. The sound gets screechy. The only option is to restart the computer. Its annoying when it happens during critical stages of the race.
Anyone knows a solution?
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
Old 26-06-2007, 04:46 PM   #12 (permalink)
Hell no it aint coz of low resources.There was a time when my sys worked perfectly fine.And my sound and all drivers r the latest available.
vutonium is offline
Old 26-06-2007, 08:30 PM   #13 (permalink)
!FREEWARES!
Akshay's Avatar
Seems to b a Windows Driver prb. Preferably reinstall ur OS. Also get appropriate updates to XP SP2. Try Autopatcher n chk which one matches ur need (Driver compatibility, updates to drivers, etc.)
MBP 13.3";
Akshay is offline
Old 26-06-2007, 08:37 PM   #14 (permalink)
Do u think I havent tried all this??
I've been using this PC since 2000.
When it was new with the same hardware it ran fine.
Even I had installed XP Pro licenced when it was just released.
All the patches were installed just when they were released.
Even the service packs.
The problem started an year back.
I've tried every possible thing.
Whenever I had called tech support at home to check my PC the PC worked just fine.
vutonium is offline
Old 26-06-2007, 10:32 PM   #15 (permalink)
!FREEWARES!
Akshay's Avatar
May b it is a hardware issue den. Try using ur sound card in andr PC
MBP 13.3";
Akshay is offline
Old 26-06-2007, 11:06 PM   #16 (permalink)
Jai Suresh
lywyre's Avatar
Check your CPU fan. It may be choked of dust. Clean it along with the heatsink. I hope this solves.
lywyre is offline
Old 27-06-2007, 09:54 AM   #17 (permalink)
Always Fresh!
shri's Avatar
@vutonium
Plz inform me if you find a solution
BE YOURSELF :)
shri is offline
Old 27-06-2007, 11:59 AM   #18 (permalink)
I tried using the sound card on a frnd's PC[new PC].It worked just fine.I've tried cleaning it.Its clean.
vutonium is offline
Old 28-06-2007, 04:00 PM   #19 (permalink)
asif1231's Avatar
could it b by any chance a hard drive problem,
love life
asif1231 is offline
Old 03-07-2007, 11:33 PM   #20 (permalink)
are you refering to your problem or vutonium's problem, I'm getting confused whos issue we are trying to solve now.
Liggy is offline
Old 05-07-2007, 12:20 AM   #21 (permalink)
asif1231's Avatar
its me who has posted the problem i cant help it if others have the same problem.
love life
asif1231 is offline
Old 13-07-2007, 07:02 PM   #22 (permalink)
hi!!
i have a dual boot p4 2.8 machine with 256mb ram and asrock 845 motherboard.a few months ago my machine started to heat up and the fan started roaring.after some days, the computer started hanging every now and then.sometimes it worked for only 10 mins and sometimes without any problem for hours.however win 98 worked fine.i tried re-installing xp but the system sometimes would hang in the process of installation only.sometimes it said it could not read the disc or the disc was corrupt.
after many tries, xp would install but the problem persisted.a technician looked after the machine and said it was heating problem.
i cleaned the heat sink, fan and checked every connector on my machine.
after that, the cpu was cool but new problem arose.the bios doesn't recognise hard-disk if dvd-rw and hdd are connected to the same cable.but when i separate them, the bios detects hdd but hangs after writing..."searching for boot **** from ide ...ok". sometimes even the screen goes blank and would appear only after a few restarts. what may be the problem? i used memtest to check ram.it was ok....please help..!!!
ankitsaraf is offline
Old 14-07-2007, 01:05 AM   #23 (permalink)
asif1231 you have all windows and game updates? r u playin this from vista? u can't alt-tab ur way to the desktop? you can try running chkdsk /r and sfc /scannow. if u think its HDD. what other software u usin? firewall/av tune-ups/regcleaners ... how many services u running in backround? what do u scan with for threats?
ankitsaraf try just connecting the HDD with xp on it. is win 98 on differnt HDD?
Liggy is offline
Old 14-07-2007, 01:12 AM   #24 (permalink)
Security freak
rocket357's Avatar
Location: 01100001 01110100 00100000 01101000 01101111 01101101 01100101 00100001
Something you might consider:
Is your BIOS set to auto-detect your RAM settings? I know I've dealt with these kinds of issues on RAM-intensive games. The problem was that my BIOS hadn't correctly id'd my RAM settings. Modifying these settings corrected the problem (check with your RAM manufacturer to get the recommended settings).
Linux Admin by profession. OpenBSD user by choice.
rocket357 is offline
Old 16-07-2007, 01:30 PM   #25 (permalink)
my machine is 2.5 years old. there was no problem for nearly 2 years.now the bios should not be a problem as the machine boots fine from a knoppix boot cd. i have only one hdd.c drive for win 98 and d drive for xp. the game which i play most is counter strike condition zero that too locally.i don't have internet at home.
when i am not able to boot the machine, how would i scan the hdd???? knoppix now doesn't recognise my hdd, so i am not even able to take backups.the bios does shows the hdd connected..
Old 02-09-2007, 11:27 PM   #26 (permalink)
Always Fresh!
shri's Avatar
can this be a ram problem?
BE YOURSELF :)
shri is offline
Old 03-09-2007, 12:07 AM   #27 (permalink)
yeah that cud be the culprit, it is possible that HDD may not be running in UDMA mode 5(i.e in PIO mode, check in device manager) and thus CPU usage for every access to Hard disk not leaving CPU cycles for any other process(here winamp)
@Vutonium : I guess this is surely the problem with yr PC so check in Device manager.
dabster is offline
Gaim keeps crashing Maverick340 Software Q&A 6 27-06-2007 10:19 AM
IE crashing why? csczero Software Q&A 5 30-03-2007 04:03 PM
system crashing tamilvendan QnA (read only) 14 15-02-2006 06:54 PM
Windows Crashing, pls help neo_anderson Hardware Q&A 4 26-01-2006 11:13 AM
- by gohan89
