Guys i need help real fast...
my comp keeps givin the dreaded blue screen thing wid numbers and checksums and restarts like every 5 mins!! what do i do????????
that Blue Dreaded Screen is known as the " BSOD : Blue Screen Of Death " ....plz give us the exact details of the error that u c in the BSOD !..only then we can help...
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
"Diagnosis:
The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values."
yeah sounds like CMOS battery is the problem or overheating, google or Microsofy's knowledge base the error. try a clean boot of the system (msconfig startup tab disable all, services tab Make sure there IS a check in hide all ms services then disable all) then reboot. or boot to safe mode, does it still happen?
either buy more RAM, or if you can swap with a friend. if you buy more RAM would suggest at least 512. Are you running any 3rd party firewall/AV? does this happen in safe mode? have you downloaded latest DirectX (9.0c). did you update your video driver recently? is this a name brand computer, or home built? have you tried to boot to ssafe mode and does the error still occur?
