Old 24-06-2007, 06:00 PM   #1 (permalink)
free as a bird
Default flashing bios
hi i want to flash my bios can any body tell me how to do it and what precaution i do need to take before flashing bios
vicky_l7 is offline
Old 24-06-2007, 07:16 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: flashing bios
1. Don't try to flash the BIOS until there is a new feature available in BIOS update! It can be dangerous to ur system (specially mobo) if anything goes wrong.
2. Most of the mobo comes with a bundled CD, in which u get a BIOS flashing software, which can automatically download the required update and can flash the BIOS.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 24-06-2007, 07:23 PM   #3 (permalink)
True Techie
nithinks's Avatar
Hey vishal, tell me few advantages of flashing. and time required for that.
http://www.mytechyard.com/
nithinks is offline
Old 24-06-2007, 07:25 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
if the BIOS manufacturer releases Windows Based BIOS Flashing, then use that, as its the most safest way of flashing.
example->Windows Based BIOS Flashing - Intel DG965WH BIOS
Important Notes:
Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes.
• If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 24-06-2007, 07:28 PM   #5 (permalink)
Microsoft MVP
1. Usually BIOS updates include a few new features and support for new hardware.
2. It takes a few minutes.
Old 24-06-2007, 07:42 PM   #6 (permalink)
Dark Star's Avatar
Flash the BIOS when major updates are available like FSB increment and all... Fashing BIOS is not too tough just you need a Floppy drive that hard to find but still I have
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 24-06-2007, 07:56 PM   #7 (permalink)
Microsoft MVP
Make sure that u hv proper UPS connection coz there should be no power fluctuation in the flashing process otherwise u'll end into a dead mobo...
Old 25-06-2007, 10:38 AM   #8 (permalink)
Talking Re: flashing bios
yup very correct...
NagpurDaMunda is offline
Old 25-06-2007, 10:42 AM   #9 (permalink)
Now a days there comes backup bios.....even due to power failure..when next time u boot and if flashing had failed.....than this backup bios comes in picture...also this chip cant be changed so never to worried about power failure.....
magnet is offline
6600 bios flashing nithun QnA (read only) 3 20-09-2006 07:20 PM
BIOS Flashing Stalker Hardware Q&A 3 18-09-2006 01:16 AM
BIOS flashing 1004 Beta 001 jaya Hardware Q&A 2 09-11-2005 03:00 AM
Flashing the BIOS nishant_nms QnA (read only) 11 25-09-2005 02:33 PM
DETAILED GUIDE TO FLASHING YOUR BIOS. anishcool QnA (read only) 3 15-10-2004 01:19 PM
- by gohan89
