Old 25-02-2005, 01:32 AM   #1 (permalink)
Default Recording fm radio
hi all,
i want to record songs from fm radio. what all things i need and how should i record, using which recording software?
onlyutkarsh is offline
Old 25-02-2005, 01:46 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
you need a cable wid stereo pins at both ends (3.5mm dia....like the one on ur earphones)...of corz an fm player...
plug-in one end of the cable to ur fm receiver and the other end to ur line-in port on the soundcard/mobo....unmute the line-in...use a software like goldwave (shareware) to record using the line-in source and use an encoder like LAME to encode the wave file to mp3.
infra_red_dude is offline
Old 25-02-2005, 01:46 AM   #3 (permalink)
swatkat's Avatar
u need a cable with Stereo jack on both sides....
do this:-
1]connect ur FM radio to Line In (or Microphone) of ur PC.
2]Next, right click the Volue Control icon in System Tray, and click "Open Volume Controls".Here go to Options>Properties menu.
3]Select the Recording radio button, and in list shown below Select (put check mark) the Line In and Microphone and click OK.
4]In the main window, u make sure that Line In is selected (not muted),and keep the Line In Volume slider to max.
5]Get a software called Audacity, and install it. After this go to File>Preferences in Audacity.
6]In the Audio I/O tab select the Channels as "2(Stereo)".
7]After this, connect ur FMradio to Line In of PC and click Record button in Audacity.
http://audacity.sourceforge.net/
http://swatrant.blogspot.com/
swatkat is offline
Old 25-02-2005, 01:54 AM   #4 (permalink)
Follow the the above steps + u can use nero sound trax to record from line in
It rocks
Stay cool always!!!
cool_techie is offline
Old 25-02-2005, 04:54 PM   #5 (permalink)
godsownman's Avatar
you can use jetaudio www.jetaudio.com limited features edition or audiograbber both are good and audiograbber is free
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
- by gohan89
