Old 24-02-2005, 07:39 PM   #1 (permalink)
Default .exe to code
i am having an exe file and i want to view its source code that is
decode the exe .anybody knows this!!!!!
CompaqVijay is offline
Old 24-02-2005, 09:08 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Use a disassembler like W32dasm, or even SoftIce. This won't give u th code, but if u have in-depth knowledge, u can understand th logic of th prog. But make sure u r not violating th terms of th license agreement.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 25-02-2005, 05:41 PM   #3 (permalink)
@CompaqVijay
so you want to do reverse engineering
@Kl@w-24
You said it all.
Overclock Me.
Overvolt Me.
AMD Me.
quad master is offline
Old 26-02-2005, 02:12 PM   #4 (permalink)
No tool can convert exe to source code.
Find one and u will be the einstein of programming world.
U can use WDASM32 or Softice or exe dumpers to see the assembly code of the program.This is often called reverse engineering and can be used to debug some common problems.
Hex editors can be used also to some extent.
WDASM 32 and hex editors are mostly used by crackers to bypass cd protections and serial checks of some softwares.
U have a long way 2 go before learning these tools.
Lovedeep Wadhwa
cheetah is offline
Old 27-02-2005, 11:45 AM   #5 (permalink)
[Edited Batty] Link deleted ..
smt_malhotra is offline
Old 27-02-2005, 04:39 PM   #6 (permalink)
Just Do It
Charley's Avatar
http://www.codearchive.com/dl.php?dlid=80
Charley is offline
- by gohan89
