Old 22-06-2007, 07:51 AM   #1 (permalink)
Default Right click not works
Hello over there i am using windows vista ultimate.Some times when i work with IE7.Suddenly the right click not works.And after closeing all the IE's and again when i reopen the IE mean it(right click) works fine.And i scan with Antivirus ,spywares etc and even reinstall the OS.I have the same problem.What could be the solution for these????
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 22-06-2007, 10:19 AM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Right click not works
Some Webpages have Righ Click diabled. Does that happen on all pages or only on some websites ??
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 22-06-2007, 10:29 AM   #3 (permalink)
it happens even in google.com
rajas700 is offline
Old 22-06-2007, 11:00 AM   #4 (permalink)
hullap's Avatar
Might be a prob on your driver.Update them
hullap is offline
Old 22-06-2007, 12:48 PM   #5 (permalink)
windows is upto date..
rajas700 is offline
Old 22-06-2007, 01:12 PM   #6 (permalink)
Formerly Spashy
Sparsh007's Avatar
as sukhdeep says it it most probably due to
tht some webpages have right click disabled
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Old 22-06-2007, 01:15 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
some websites intentionally disable rt click to prevet copying or seeing of the code, by adding a simple javascript. however browsers (maxthon atlst) has a plugin which can enable agn such disabled rt-clicks.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-06-2007, 07:07 PM   #8 (permalink)
lol all read my the above reply below to sukhdeepsinghkohli..Right click not works even in google.com do they diable???
rajas700 is offline
Old 22-06-2007, 08:03 PM   #9 (permalink)
Formerly Spashy
Sparsh007's Avatar
It Works in google.com
Proof:-
Old 22-06-2007, 08:08 PM   #10 (permalink)
Host4Cheap.org
Proof:-
LOL Yes we know, but somehow for him it doesnt. Dont know solution for your problem
Old 22-06-2007, 08:46 PM   #11 (permalink)
Formerly Spashy
Sparsh007's Avatar
oh k but hes not asked for a solution
Old 22-06-2007, 09:50 PM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
@Sparsh007- Look carefully ...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-06-2007, 09:59 PM   #13 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Well the problem could be anything...
1.) Your mouse may be faulty...Check it. Is it workin in XP.
2.) you probably have a bad context menu handler registered for certain file types. Uninstall any software which adds entries in context menu. And then check.
3.) Sometime it takes 4-6 secs. because of high ram consumption.
Quiz_Master is offline
Right Click = Left Click emailaatif786 Hardware Q&A 6 26-03-2007 02:48 PM
how dvd ram works jenaguru QnA (read only) 1 20-09-2006 01:21 PM
how dvd ram works jenaguru QnA (read only) 2 19-09-2006 09:39 PM
how click increasing site and sofware works?? QnA (read only) 5 20-08-2005 04:34 PM
- by gohan89
