Old 21-06-2007, 01:49 PM   #1 (permalink)
Question DVD doesn't get recognised..!!!
Guys recently i purchased an original DVD movie.When I tried to play it in computer the DVD drive didn't recognise the DVD at all.It shows the message "There is no disk in drive x:".I tried to play it using VLC Media player but in vain.The player too didn't recognise.What will be the problem and will it be due to any region code problem with my DVD drive.I used Nero info tool and found that my DVD drive has got no region code enabled and region control is set to RPC II.When I tried to play it in my DVD Player,the DVD gets recognised and it plays smoothly.But the problem is i can't forward,rewind,change language or do any other operations with it. Why is it so?My DVD player is an old and a local model.My system specs are Pentium IV 2.4 ghz,Intel 865g motherboard,256 MB ram,80 GB HD,sony DVD drive,Geforce 4 MX graphics card.Please help me out..!!
rakesh-the gilli is offline
Old 21-06-2007, 04:42 PM   #2 (permalink)
ramprasad's Avatar
Default Re: DVD doesn't get recognised..!!!
Ur DVD Drive is the culprit
some discs, even though how good it is, is not recognised in Sony Drive
ramprasad is offline
Old 21-06-2007, 09:42 PM   #3 (permalink)
Is actually a real word..
yeah I agree, Sony has problems with all there laser units, doesn't matter what you buy from sony and it has a laser, you're pretty well screwed. I'm waiting to see what those new ps3's are like. give 'em a few years and I bet people will have issues with them not reading disks.
Liggy is offline
Old 21-06-2007, 11:19 PM   #4 (permalink)
Guys then do tell me some way to see my DVD and the DVD film "DON" given by digit is recognised by the drive but only for a short time.When the film is played using VLC it opens,plays it for 3 secs then it just closes..What shall i do...?
Old 22-06-2007, 12:33 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Try the same DVD on ur frnd's computer.If it plays well..than for sure there is problem in ur DVD player.
Try to clean the lence of DVD player.
ravi_9793 is offline
Old 22-06-2007, 04:10 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
insert a dvd lens cleaner ........
ax3 is offline
Old 22-06-2007, 05:40 PM   #7 (permalink)
slugger's Avatar
if d disk iz getting detected then u may want to extract it using DVD Decrypter
http://www.mrbass.org/dvdrip/
and then watch it directly from the HDD
slugger is offline
USB drive not recognised in Windows XP sanjiban_ghosh Hardware Q&A 1 27-12-2006 07:05 PM
Some discs noty recognised... mario_pant Hardware Q&A 7 01-07-2006 09:19 PM
Floppy Media not recognised Plz help angel_dinesh QnA (read only) 11 07-07-2005 05:10 AM
- by gohan89
