Old 24-02-2005, 01:42 PM   #1 (permalink)
Default RAM query(urgent)
Hi,
well I have to change my frends RAM(lady ) without looking dumb.she has an old PC which has SDRAM(100 mhz)..I checked in her PC that a new hyundai 128 Mb(133 mhz) module works perfectly in other words without any glitch..But what got me edgy is that she has her old 32Mb(100mhz) module still with her which she wants also in the second available slot..
now my query is wether a 128mb ram(133 mhz) work flawlessly in tandem with 32mb ram(100mhz)...Do enlighten me plz..am in a real hurry..I dont want any messy situations there...
she has a Compaq Pc of 4yrs with Win 98SE,celeron,433 mhz, 40Gb HDD.....
Kindly also tell wether the choice of my RAM company is good or bad.i guess not many cos make SDRAMs anymore..But still comment..
Thanx
krisjr is offline
Old 24-02-2005, 02:12 PM   #2 (permalink)
Yes it will work but the combination will make both the ram modules to run at 100MHz only. Not a major problem i think so go ahead with it.
**** happens
pradeep_chauhan is offline
Old 24-02-2005, 03:53 PM   #3 (permalink)
tx dude for the info.well what if i dont add that 32mb(100 mhz) RAM in second slot..will it run at 133mhz..because the new one am geting is of 133mhz type..Only if i add the old 32mb(100mhz),it will run at 100mhz...Is that what u saying mate..
do tell me...
tx
krisjr is offline
Old 24-02-2005, 04:24 PM   #4 (permalink)
yea thats exactly what he is saying. And you might consider still putting in the 32 MB Ram cos the diff between 133mhz and the 100 mhz may be outweighed by the extra 32 MB ram.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 24-02-2005, 08:25 PM   #5 (permalink)
tx.but will the speed me better(far better) than earlier or not..am planning to install xp also...having said that,wat do u say,will it work properly..
do let me know
krisjr is offline
Old 24-02-2005, 11:47 PM   #6 (permalink)
I suggest throw out or exchange the 32M ram for a 128/256 DIMM 133Mhz it will be better and you will see areal improvement in the system performance more so with win XP
**** happens
Old 25-02-2005, 12:11 AM   #7 (permalink)
Ok mate final check..i was thinking in those lines..but i was again thinking wether a 160mb(128[133]+32[100]) is better option than a single module of 128(133)...Do suggest mate.
krisjr is offline
Old 25-02-2005, 02:20 AM   #8 (permalink)
swatkat's Avatar
Default Re: RAM query(urgent)
Originally Posted by krisjr
Hi,
Thanx
keeping 128MB@133Mhz and 32MB@100MHz means both will run at 100Mhz.....
or buying another 128MB or 256MB running at 133MHz, and coupling these two will make both run at 133MHz.
but, another thing is being overlooked, Celeron 433Mhz processor has a FSB of 66MHz....
FSB (Front Side Bus) is the bus connecting CPU and System Memory. so, celeron has this bus speed of 66MHz....and hence teh memory modules r transacting with CPU at a speed of 66MHz instead of 100MHz or 133MHz....
Also, even though 133MHz is 33% faster than 100MHz modules, the actual performance difference between the 100Mhz module and 133MHz module is only 5% to 10%....
so it's better to keep ur old 32MB with the new 128MB one, and 160 MB is enough for XP with some eye candies turned off.....
http://swatrant.blogspot.com/
swatkat is offline
- by gohan89
