Old 24-02-2005, 12:41 PM   #1 (permalink)
Default help required, please!
hi ya all,
i'm having a small problem, u see, here are my pc specs:
p4 2.4 ghz, win xp sp2, dx9.0c, 512 mb ram, geforce fx 128 mb
here is my problem:
recently, i was installing prince of persia :warrior within pc game, i inserted cd1 and it was installed, then it asked for cd2, it was also installing well, suddenly, an error message popped up, saying "The Wrong Volume is in the Drive h:, please insert popww_1", and it didnot went away even when i switched the cd's, so i had to abort installation and then error message kept coming up for which i had to restart. now, today, i was installing star wars knights of the old republic 2 pc game from .cue images via alcohol 120%, and the same thing happened after some time, this time my dvd drive was not even used, the cue files were copied on hdd by me and then they were being installed via virtual drive i:, please tell me am i missing any files, also, how to enable autostart on my dvd drive?
Thanks.
--Whoa--
neo_anderson is offline
Old 24-02-2005, 12:49 PM   #2 (permalink)
Ethan_Hunt's Avatar
There must be a possiblity of source corruption of the Disc.....Now the main question Is it a Original or A Pirated Version....Cause usually pirated versions occur with these errors
Also try installing the disc on some of ur friends system....and see if its works
V for Vendetta
Ethan_Hunt is offline
Old 24-02-2005, 04:54 PM   #3 (permalink)
positively ur Disc got corrupted! or U r having a pirated version .... improperly burnt on ur Disc 2 ...
try it on some of ur frd's comp.... as Allwyn said
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 24-02-2005, 09:06 PM   #4 (permalink)
new games are smart when it comes to the disc u install from
u definitely have a pirated version
solution : buy original software/games for painless installation / after sales service
No Mercy, No Limits.
theraven is offline
- by gohan89
