Old 24-02-2005, 12:15 PM   #1 (permalink)
Default hard in hard ware and naggging screen
"I CANT EVEN PLAY MAX PAYNE 2 I AM REALLY FRUSTRATED"
i have a celeron 1.2 Ghz with 128 ram "HIS" mother board with onboard grapics and sound .it has a intel chipset 810.it does not support "open GL" .pl. tell me if i can download drivers so that it can support "open gl" .if yes from where .
recently i deleted a program as i did not had its uninstaller .now when i switch on the pc .after the windows screen it shows
" a file refered to in your registry or system.ini is missing .which may be required to run windows or one of its application.pls restore the fie or uninstall the program
aspendium.vxd
press any key to continue
after pressing key everything continues normally
but i bugged off by waiting at the terminal every time i switch on the PC.
plz HELP......
WHEN THINGS GO WILD CYBO GET WILDER
LINUX ROCKS
WIND SUCKS
its still sucking
cyboincomp is offline
Old 24-02-2005, 12:19 PM   #2 (permalink)
why need title?
bharathbala2003's Avatar
urs is a onboard Graphics card.. it will not support Open GL.. better get a GFX card for furtur help on GFX
Graphics Cards
bharathbala2003 is offline
Old 24-02-2005, 12:23 PM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
[1] What game r u trying to run ? Maybe u just need to update ur gfx drivers. However, almost none of th latest games will run on ur hardware.
[2] Reinstall that program. Now, go to 'Control Panel'>'Add/Remove Programs' and uninstall th program from there.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 24-02-2005, 01:13 PM   #4 (permalink)
enoonmai's Avatar
The Intel 810 motherboards DO support OpenGL. You can definitely play Q3A and RtCW, cant you? The next time the game loads check for the GL_RENDERER variable.
Having said that, it also depends on the game you're running. While CoD, MOHAA all use a modified Q3A engine, their requirements cannot be met by the 810 even though it supports OpenGL. In that case, you have to get yourself a video card that features at least 32MB of video memory and Hardware Transformation and Lighting (TnL) support at the bare minimum.
Are you sure its aspendium.vxd and not aspienum.vxd? Because if it is, then its the ASPI enumerator for Windows and can be fixed by downloading and reinstalling the ASPI Layer. The ASPI packages can be downloaded from here:
http://www.adaptec.com/worldwide/sup...dkey=ASPI-4.70
And do post what game it is that you're trying to run.
Playing FEAR XP/LSW2
enoonmai is offline
Old 24-02-2005, 01:16 PM   #5 (permalink)
Ethan_Hunt's Avatar
Hmmm.....now i used to run Q3Arena on the Intel 810 Previously....the games definetly reqd Open Gl support....guess how that ran now????
yes it is compatbile with Open Gl Support Just that some drivers have issues running with these chipsets:
http://support.intel.com/support/gra.../CS-009471.htm
try downloadin Latest drivers from
http://www.softwarepatch.com/utilities/intel810.html or from intels official website
Also try http://opengl.org/
@bala....mate i dun suppose he can add a Gfx Card as 810 Mobo aint supportin Agp Card upgrade.....i guess he'll have to change to whole mobo with Agp support for addin a Gfx card
@cyboincomp....welcome to thr forum and have a good time around here....read the rules and then start postin
V for Vendetta
Ethan_Hunt is offline
Old 24-02-2005, 03:59 PM   #6 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Heck, MOHAA runs perfectly on 810e (at low detail, of course), though CoD refuses to do so.
And yes, u will need to replace ur mobo if u want to play th latest games, coz it doesn't have an AGP slot.
Flickr!
Old 24-02-2005, 05:34 PM   #7 (permalink)
Ethan_Hunt's Avatar
yup Medal Of honor:AA Works On an Intel 810 onboard Gfx but If not provided with sufficent Ram The Game jerks Out as Always....Btw COD Is much more advanced and The game and Gfx Engine Is more Gfx Hungry and henece aint proving worth on the Obnoard Gfx Of 810
@cyboincomp......Sorry mate had missed out ur other query there.....Well obviously looks like u have deleted some System file.....Just try Running Sfc (System File Checker) By Clicking on Start-Run And type Sfc And press Enter.....And Then let it check for the Missing files and replace em....just provide the loaction of ur OS's (98 or Xp or any other) installation directory manually and ur done
V for Vendetta
Old 24-02-2005, 05:47 PM   #8 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
The file u mentioned seems to refer to ASPI drivers. Reinstall th ASPI drivers and th problem should be solved.
Flickr!
Old 18-10-2006, 07:15 AM   #9 (permalink)
Talking Re: hard in hard ware and naggging screen
MUTHARE
Own A Inspiron Core 2 duo 6400 lappy, 1 GB ram, 128 X1300 ATI, 8X DVD-****, 667mhz FSB, 100GB hdd.
kumargautam2003 is offline
- by gohan89
