LinkBack (1) Thread Tools Search this Thread Display Modes
Old 19-06-2007, 12:43 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
nix
Senior Member
nix's Avatar
Default howto: bypass startup login screen?
whenever i switch on the comp, i get this login screen...it asks to enter password...i have to hit enter, only then will it proceed to complete startup..how do i bypass this?
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 19-06-2007, 03:58 PM   #2 (permalink)
Default Re: howto: bypass startup login screen?
Bypass The Windows XP Log On Screen
Click [Start] [Run] and type
control userpasswords2
Click [OK]
The [User Accounts] Property Sheet displays.
On [Users] tab, clear the [Users must enter a user name and password to use this computer] check box.
Click [Apply].
Enter a user name and password that should be used to logon automatically in the dialog box that appears.
Click [OK].
Go to [Control Panel] [User Accounts] [Change the Way Users Log On and Off].
Uncheck [Use the Welcome Screen] and [Use Fast User Switching]
ismart is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/60782-howto-bypass-startup-login-screen.html
Thread How to bypass startup menu and boot directly to windows - HP Support Forum | HP Support Forums | BoardReader This thread Refback 25-03-2011 05:50 PM
Wallpaper before login screen g_goyal2000 QnA (read only) 7 21-05-2007 01:43 AM
howto start X bypassing the login screen? & related Q's cranky Open Source 5 21-03-2007 01:32 PM
Login Screen Problem Shikher_neo Software Q&A 4 23-12-2006 11:04 PM
login screen removal gofeddy Software Q&A 4 23-11-2006 01:11 AM
How to change the login screen? shashank_digitreader Software Q&A 5 31-10-2006 09:11 PM
- by gohan89
