Old 19-06-2007, 12:35 PM   #1 (permalink)
Default JPEG+AVI files
Hi,
I am using latest version of Nero. I want to write cd which can play JPEG files & avi both.
Plz let me know how to do that?
I dnt want to make JPEG file into MPEGAV bcz we cant copy the picture in that format.
Could AVI should be convert into cd's player format before writing?
OR any other s/w for that solution..
rgds
Himanshu
Him007 is offline
Old 19-06-2007, 12:38 PM   #2 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Default Re: JPEG+AVI files
First check whether ur cd player supports avi or not
bhushan05d251 is offline
Old 19-06-2007, 12:49 PM   #3 (permalink)
No it is not supporting the AVI files.
Him007 is offline
Old 19-06-2007, 01:01 PM   #4 (permalink)
Then u hv to convert it into standard VCD or SVCD format using Nero Express (not Nero Burnint ROM) to play it into ur CD Player. U can add pictures also. Ur pictures will automatically stored in "PICTURE" folder during burning process. If u want to use Nero Burning ROM then u have to create PICTURE folder in data section. and then insert pictures.
Old 21-06-2007, 09:08 AM   #5 (permalink)
& what abt the AVI file, which can be saved in the same cd. Do we need to convert the avi file into mpgav format to play on the normal dvd/cd player?
plz reply..
Him007 is offline
.emf to jpeg sivarap QnA (read only) 8 13-04-2007 01:05 PM
How to Convert .rtf to .Jpeg keves2002 QnA (read only) 9 21-01-2007 08:37 PM
djvu to bmp jpeg ? mkmkmk QnA (read only) 2 24-06-2006 03:27 PM
jpeg to vcd? taran00 QnA (read only) 8 22-08-2004 11:11 PM
- by gohan89
