Originally Posted by Nemesis
arre guys...direct copy+paste frm PDF to DOC is very much posiible
If your PDF document has a lot of tables and you want to import them right in DOC format, you're out of luck. Because even with Word 2003's "Match Destination Formatting" option, all your tables, their cells, images, alignment, everything gets shot to kingdom come if you do a direct copy-paste. Like I said, I've tried lots of software for this, and ONLY pdf995 can convert it to an "acceptable level" (read as one hour of work reformatting everything)
Originally Posted by drgrudge
For converting .doc to .pdf, adobe reader does that
If you mean the free, limited conversion capabilities of Adobe Online accessed via the Reader program, then yes, I guess it can convert. To take full advantage of the PDF conversion process, you need either Adobe Acrobat Standard or Professional.
