Old 17-06-2007, 09:35 AM   #1 (permalink)
ashfame's Avatar
Default Urgent Adsense Help
I implemented blogger hack for adding adsense ad after posts (On Post Pages)
I chose a banner (468 x 60) but after implementing the code, I am having a wierd banner of size (158 x 600).
The thing is that if I change <!-- with &lt;!--
and //--> with //--&gt; in the adsense code.
I am getting the ad in the same format I want (468 x 60).
Many bloggers says this is allowed as code is not altered but I want to confirm from bloggers here!
I have enquired Adsense help on this but I have not recieved any solution yet.
Kindly suggest a soln ASAP!
HELP guys!!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 18-06-2007, 04:00 PM   #2 (permalink)
ashfame's Avatar
Default Re: Urgent Adsense Help
Pl somebody help
ashfame is offline
Old 18-06-2007, 04:04 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
AFAIK your change will only make the page show < and > rather than treat it like a tag. What is it that you actually want to do? Change dimensions right?
That's not possible cause the Ad server supports only the available formats and those are downloaded using thier respective IDs. So you can not get your desired dimensions no matter what
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-06-2007, 04:55 PM   #4 (permalink)
ashfame's Avatar
No NO
u got me wrng
I chose a diff ad format than the one which is showing
changing da code <!-- with &lt;!--
and //--> with //--&gt; doesnt alter any code
but just the tags
ashfame is offline
Old 20-06-2007, 11:53 PM   #5 (permalink)
ashfame's Avatar
I tried changing the ad to link ad bt still that damn tower is displayed
pl help guys
ashfame is offline
Old 21-06-2007, 08:49 AM   #6 (permalink)
Commander in Chief
I still don't understand your problem. Is it a template issue?
Harsh J
www.harshj.com
Old 21-06-2007, 08:51 AM   #7 (permalink)
ashfame's Avatar
actually!
Chk any post page on my blog http://tech4sure.blogspot.com
I am getting a wierd ad in the middle column after the posts content
ashfame is offline
Old 21-06-2007, 09:01 AM   #8 (permalink)
Commander in Chief
Hm, that's odd, the code I see you've implemented there is funny, its got no PUB ID number in it, nor style formatting.
<center><div>
<script type='text/javascript'>
</script>
<script src='http://pagead2.googlesyndication.com/pagead/show_ads.js' type='text/javascript'>
</script>
</div></center>
Make sure you implement a proper code, cause I don't think this will generate any clicks for you, its got no info for that. And nor is it legit.
Harsh J
www.harshj.com
Old 21-06-2007, 09:04 AM   #9 (permalink)
ashfame's Avatar
No!
here is my implemented code:
<center><div>
<script type='text/javascript'><!--
google_ad_client = "******************";
google_ad_width = 468;
google_ad_height = 15;
google_ad_format = "468x15_0ads_al";
//2007-06-20: adsense hack
google_ad_channel = "3577313597";
google_color_border = "FFFFFF";
google_color_bg = "FFFFFF";
google_color_link = "0066CC";
google_color_text = "000000";
google_color_url = "0066CC";
</script>
</script>
</div></center>
i hav my pubID behind ****************
and if i change dat code to
<center><div>
<script type='text/javascript'>&lt;!--
//--&gt;
</script>
</script>
</div></center>
it works fine
ashfame is offline
Old 21-06-2007, 09:11 AM   #10 (permalink)
Commander in Chief
You might have implemented that but what's actually getting shown (Due to some error, or term violations maybe) is this:
http://img361.imageshack.us/img361/6315/ashfamege1.jpg
Harsh J
www.harshj.com
Old 21-06-2007, 09:14 AM   #11 (permalink)
ashfame's Avatar
wt shd i do now?
my blog log stats shows three clicks on adsense ad but i dont get any clicks for yesterday!
Edit
Got 2 clicks credited
ashfame is offline
Old 27-06-2007, 06:18 PM   #12 (permalink)
ashfame's Avatar
I found this link stating that replacing is true: http://www.blogcrowds.com/forum/viewtopic.php?t=616
Tell me guys what you think about it.
Also now just no ads are appearing (the wierd one only, others are fine)
pl help yaar!
ashfame is offline
Adsense Help!!!!! deepgeek2 Software Q&A 2 07-09-2006 01:38 PM
Adsense help ashfame QnA (read only) 8 04-05-2006 01:33 PM
How to use Adsense ? adityainalps QnA (read only) 2 17-03-2006 10:38 PM
- by gohan89
