Old 23-02-2005, 01:31 PM   #1 (permalink)
Default Review Needed on Compaq Presario SR1350IN
HI
Can anybody provice me a user / critical review of Compaq Presario SR1350IN ? As I intend to buy it ASAP. Is it a good buy if i can get it at say around 36 K., I belive the MRP will be around 40 K.
regards
Rahul
rahulonline is offline
Old 23-02-2005, 08:21 PM   #2 (permalink)
Hey rahul
are you sure that you want to go for a branded PC.
5Years ago i made a mistake of purchasing a branded PC.
I would suggest you to reconsider your thinking as the flexibility
you could get with a assembeled PC is gr8.
Well this is the config i can suggest to you
AMD Athlon 64 3000+ S754 [Rs 6716 Digit Feb 2005 Rate][might be less]
ASUS K8N-E Delux [Rs 8736 Digit Feb 2005 Rate][might be less]
nForce3,6SATA with RAID,Gigabit,7.1Audio
Samsung 793s - [Rs 6000 max Mumbai Lamington Rate]
Transcend 512MB DDR400 [Rs 3500 approx]
Samsung 52x CDWriter with 8MB Buffer [Rs 1300]
Sony DDU1621 DVDRom Drive [optional Rs1300]
Samsung 80GB 7200rpm SATA HDD [3200Rs Max Mumbai Lamington Rate]
Sony Floppy Drive[Rs 300]
Good Cabinet [around 800]
Power Supply 350Watts [dont know if VIP has a 350W] [Rs1000 max]
A good Geforce 5600 GPU would be good enough
XFX GeForce FX 5200 - 128MB is good for Rs3000
Its upto you to go for a branded or a assembeled.
Let others also place there views.
Overclock Me.
Overvolt Me.
AMD Me.
quad master is offline
- by gohan89
