Old 16-06-2007, 01:14 PM   #1 (permalink)
Default using multiple connections
I have got two phone lines two modem two dial up user accounts from same isp. I can connect to both of them simultenously but i dont get the double bandwith. I heard that there is some kinda software to use bandwith of both connection. what is that?
rishav is offline
Old 16-06-2007, 03:45 PM   #2 (permalink)
24online's Avatar
Lightbulb Re: using multiple connections
how one can download one file on two different IP?
i think it is not possible....
**#(o)#**
24online is offline
Old 16-06-2007, 03:59 PM   #3 (permalink)
blackleopard92's Avatar
Default Re: using multiple connections
no, it is. i exactly don't know the procedure. but had used it looong time ago in age of dial ups. simply no idea how to do it.
blackleopard92 is offline
Old 16-06-2007, 04:27 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
see, Only Public ISP know to me, that support multi connection bridging is BSNL ISDN !!!
There one may bridge 2 or more ISDN lines, apart from that no other ISP support this in India so far...
and certainly its not possible to bridge between ISP A and ISP B...
How ever there are few costly hardware from Cisco is available which may do this for you, you gave to google them as because they are way my budget therefore i never took any purchase rate
anyway, this question is asked many times in this forum... search !!!
http://www.thinkdigit.com/forum/sear...earchid=275151
thank you...
using 2 internet connections simultaneously on pc
merge 2 net connections
combining two ISP..
integrating two internet connections
Using Two Internet Connections at The same time
connect via LAN and Dial up together
Can I connect 2 internet connections Connect at a time?
and many many more...
rebooting
ChotoCheeta.com
Last edited by Choto Cheeta; 16-06-2007 at 04:27 PM. Reason: Automerged Doublepost
Choto Cheeta is offline
Old 17-06-2007, 07:16 AM   #5 (permalink)
thank you...
combining two ISP..
thanks bro there were so many chained lnks. anyways the problem i read in those 10 posts n mine is completely diffrent. here its how,
My ISP uses NAT for ppoe. This means that my computer A connected to ppoe to my isp has some different private ip but same public ip tht my computer B connected to ppoe to my isp has. This means that computer A and computer B or any other thier clients has the same public ip. Now what I have done is enable ICS(Internet connection sharing) on computer A. That means using computer A as gateway I can browse internet on Computer B. The good news is that I have another ppoe connection available on computer B to connect. So after i connect computer B ppoe, I want to combine the power of Computer A and Computer B bandwidth. I know therez a software just forgot the name.
Remember No different public IP.
rishav is offline
Old 17-06-2007, 10:59 PM   #6 (permalink)
Rebooting
How come there is no different public IP ??
Computer A get conneceted to the net with PPPoE getway 1, which u share with Computer B... OK... now comouter B has its own PPPoE getway...
so ?? How come the Computer A's getway IP and Comouter B's Getway IP b same unless their Getway's are same ??
rebooting
ChotoCheeta.com
Old 17-06-2007, 11:09 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
I called my ISP (airtel)..and asked for the same.They said this is not possible but didn't gave any Strong reason for this.
ravi_9793 is offline
Old 18-06-2007, 07:40 PM   #8 (permalink)
well I'm using computer B. So computer B's local area connection has the gateway of comuter A i.e 192.168.0.1, computer A has 10.67.67.66, n then 192.168.5.1 and finally publick ip 202.202.202.202*
and the compute B has its own ppoe which when connected has ip 10.67.67.67, gateway 10.67.67.67 n then 192.168.5.1 and finally the same public ip 202.202.202.202*
* assumed IP.
rishav is offline
Can we have multiple net connections at a time? go4saket QnA (read only) 4 17-05-2007 06:08 PM
multiple internet connections Gaurav Internet & WWW 6 27-05-2005 10:16 PM
Sharing multiple net connections shriekers QnA (read only) 3 03-04-2005 03:18 PM
How To Add Multiple MX Entries And Set Multiple Preference? tuXian QnA (read only) 7 03-03-2005 06:23 PM
about ftp connections Neeraj QnA (read only) 4 20-12-2004 12:32 AM
- by gohan89
