Old 15-06-2007, 06:24 PM   #1 (permalink)
Default CD Writing
Hi,
In my windows xp (c drive) there was 800 MB space, Today I just put the blank cd in the writer & pasted the some songs folder on the cd & write it using WM10.
After that only 150 Mb left in the c drive. I chked the temp folder in windows Dir & as well as in the administrator temp folder but cldn't get any file;
So where are these temp files; bcz my drive is running short of the space,,,,,plz help
Him007 is offline
Old 15-06-2007, 07:20 PM   #2 (permalink)
rohus24's Avatar
Default Re: CD Writing
run ccleaner frm www.ccleaner.com and itll remove it
b4 this jst go to start> run > type %temp%
hit enter if its der then del it
rohus24 is offline
Old 15-06-2007, 07:26 PM   #3 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Thats because the files are created in Cd Writing cach folder.
It will be in your
c:\doucuments and settings\administrator\local settings\cd burning
(I am not sure about path so search for Cd burning folder.)
Delete all files there. And u r done,
Also install CCleaner. And remeve all temporary files.
## Yippie. My 400th Useless Post on this forum. Look ma I just turned 400. ##
Quiz_Master is offline
Old 15-06-2007, 07:41 PM   #4 (permalink)
Thnks; I will do & update you....
Him007 is offline
Old 15-06-2007, 08:48 PM   #5 (permalink)
::cyborg::'s Avatar
:)) - KEEP SMILING
::cyborg:: is offline
Writing DVD RWs... shyamno Hardware Q&A 13 02-05-2007 12:53 PM
DVD writing srimaya_rath Software Q&A 11 06-12-2006 02:31 PM
USB writing pad 4 PC cooldude Hardware Q&A 1 18-10-2006 10:58 AM
Help in DVD Writing stalin QnA (read only) 7 10-05-2005 11:02 PM
cd writing noblefriend2002 QnA (read only) 2 20-08-2004 06:03 PM
- by gohan89
